Question about Linksys Wireless-N WRT150N Router
Is there a way to use command prompt to check the linksys username and password? we can't recover it
    Problem Solver:
  • 9 Answers
Here is a solution besides command prompt :
Reset the system If you can't find or remember the password, it's best if you just reset everything. All you need to do is press the reset button. Hold it for 90 seconds or so. Let the button go. This should allow you to reconfigure the system. If the system does not reset, press the button again. Hold it down for a couple of minutes and release. Check the manual for a guide on how to reconfigure the system.
To manage LinkSys router passwords, connect the Ethernet ports to the computer. Go online and log in to http://192.168.1.1/. You'll see a dialog box appear. It will ask for the username and password. Just enter "admin" for both fields. In some cases only the password field needs an entry. Just enter "admin".
If this was helpful then give me the thumbs up if it wasn't ask the question in more detail describing your situation.
Posted on Jun 15, 2009
Change password
access your router configiration to check what is your gateway address click start button then go programs then click accessories then click command prompt. From the command prompt type ipconfigand press enter
get the default gateway address and type that into the address bar of the Internet Explorer and press enter. you will be ask for username and password you must type your router username and password. inside the router configuration you can configure/change password for your router as well as the password for your wireless.
Sep 10, 2011 | Linksys WRT120N Router
How do I set the Linksys router back to its default settings?
Hello dabb481, to reset the settings on the router, try resetting it. There should be a button on the back of the router called "reset" try that option. Otherwise go to Command Prompt and type in without quotes "ipconfig" it should be something similar to 20.4.4.1 or 192.168.1.1 <----- Try that. Then log into the router. You should know the password and username. "username should be Admin, same with password if you haven't changed it" I hope this helps.
Apr 24, 2011 | Linksys Wireless-G Broadband Router
I have a start up disk for a newer linksys but i think something must be wrong with my new router. i want to know if i can use the same start up disk for my old router
You can try to access the router using the ipaddress:
1. go to the command prompt. 2. type in ipconfig. 3. look for the default gateway. 4. open your browser and type in the default gateway. 5. username is "username" password is "password"
Thanks
Jul 30, 2010 | Linksys Wireless-G WRT54G Router
I cannot gt into the router
Hard reset properly for 30 secs. & Powercycle and try again.
Mar 17, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I am having url 192.168.1.1 and other combos fail for Linksys wrt54gs. I am online with the Linksys but want to access and have a secure line rather than unsecured line. It is connected to our desktop...
To access the router setup, open an IE browser, on the address line: http://192.168.1.1 then press enter, you should be prompted for a username and password, leave the username blank, password is: admin, this should give you access to the router.
http://en.wikipedia.org/wiki/Linksys_WRT54G_series#Default_settings
if for some reason that doesn't work, start, run, cmd, enter, this will open a command window and type the command IPCONFIG /ALL look up the default Gateway IP address and see if it is different. If the gateway is a different IP address, try that IP address
Mar 02, 2010 | NetGear RangeMax WPN824 Router
Forgot my password for router or ip addressed
by default leave the username blanck and password is admin, for the ipaddress go to command prompt type in ipconfig then hit enter, the gateway is the ipaddress
Oct 20, 2009 | Linksys Wireless-G WRT54G Router
Locked out of laptop :(
If You just installed Ubuntu and forgot what password you selected during the installation process or one of your friend gave you ubuntu computer without giving username and password.This tutorial will help you to recover username and password
1) Turn on your computer, and as soon as you the Press Esc to enter grub message, press the escape key.
2) Select the option that says (recovery mode).
3) Your PC will boot into a shell. Once you get a command prompt, type “passwd username” where the username is your username. If you can’t remember your username, then you can type “ls /home” which should bring it up.
4) Enter a new password when prompted, and again when prompted again Type “shutdown -r now” to reboot your system,
That’s it. You should now be able to login with your new password.
Jun 02, 2009 | IBM ThinkPad T20 2647 Notebook
Unable to Connect to Internet
Make sure that the cable/dsl modem is connected to the blue port on the Linksys router that say's internet and your computer to any of the yellow ethernet ports. Check what is the IP address of your computer by typing ipconfig on the command prompt(assuming your using Windows, to open command prompt click start and go to Run and type cmd, a black windows will open normally it will say C:\Document\Settings\Owner>. Your computer should obtain an IP address of 192.168.1.x, open Internet Explorer and type this address on the address bar http://192.168.1.1 when you get a prompt for a username and a password, leave the username blank and type "admin" for a password from there you can now check the entire settings of your linksys router, check the Status and make sure your router is getting a valid Internet IP address if not you may require manually setting up the configuration of your ISP on the router.
Aug 29, 2008 | Linksys RangePlus WRT100 Wireless Router
Linksys Wireless-N WRT150N Router Logo
80 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
