Question about Cakewalk Kinetic 2 Full Version for PC (3112)
Activationcode for Kinetic 2
Thx
WHAT IS KINETIC ENERGY
kinetic energy is an expression of the fact that a moving object can do work on anything it hits, it quantifies the amount of work the object could do as a result of its motion.
Mar 19, 2015 | Watches
What is the measure of the average amount of kinetic energy of the atoms are molecules in a material
The average kinetic energy of a distribution of free non-interacting particles is related to the absolute temperature.Thus the absolute temperature is a measure of the average kinetic energy of the population.
May 09, 2014 | Computers & Internet
Kinetic Loud Speaker KA-4260
Kinetic speakers are generally 8 ohm, so they should work fine with the Onkyo.Your amp has a rating of 80 watts per channel, but I'm not sure of the power handling of the speakers.
Feb 08, 2014 | Audio Players & Recorders
Simple pendulum
When giving physical quantities you cannot omit the units. (an angle of 10 what). You cannot solve the problem fully because you are missing the length of the pendulum.
You cannot use any kinematic relations because the expression of the period depends on the assumption that angles of rotation remain small.
You will have to use the energy conservation principle. Assuming that the mass was released with 0 initial kinetic energy, the kinetic energy at the lower point (angle 10 degrees) is equal to the change in potential energy between the release point and the point where the mass is.
(1/2)mv^2=delta Ep= Ep(30 deg)-Ep(10 deg)
Once you calculate the potential energy (see screen capture) difference you will see that it is proportional to m*g, so the mass will cancel out.
fa4a24ac-c4c2-48d5-9f73-9560389da196.pngYour turn: Calculate the potential energy difference between the positions at 30 deg and 10 deg, equate the result with the kinetic energy and solve for v^2, and hence for v the tangential velocity.
Nov 06, 2013 | Computers & Internet
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
10 year old Seiko Kinetic (model5M62-0B00) blue face. Last week stopped and after some shaking started again but seconds moved in 2 sec intervals for a few hours. Went OK for a week and again last night...
After 10 years it will be likely that the Kinetic capacitor will need upgrading. Your watch is designed to tick in two second intervals to tell you the power is very low. The power button will work again when it has some power to show. Yorkshire Watches www,yorkshirewatches.co.uk can do the upgrade for you if your in the UK. Give them a ring.
May 23, 2011 | Seiko Kinetic watch
What,s kinetic energy ?
Kinetic Energy Kinetic energy is energy of motion. The kinetic energy of an object is the energy it possesses because of its motion.
Feb 13, 2011 | Computers & Internet
On my sports 50 it stops if it is off of my wrist for 14 hours . Also I dont know how to change the day sign to english
This is obviously unsatisfactory and I can understand your problem. Even spring driven automatic watches will run for 2 - 3 days when not worn.
Your watch can either be charged by use (i.e. wearing it) or by winding the crown wheel, although there seem to be a variety on kinetic watches and it is not clear if all of them can be wound by hand (mine can't but it goes to sleep after two days and can stay in this mode for 3 months and re-starts when it is worn!)
For a fully description of the kinetic operation go to http://www.seikowatches.com/technology/kinetic/kinetic_dd.html and there you will will see a choice of kinetic watches.
You can also access the instruction manual list to check out how your watch is intended to operate. Some watches indicate days in two languages (as yours appears to do) and you can select the correct day by pulling the crown wheel to the middle position where you generally change the date by rotating it forward and the day by turning it backward. When turning it backward, you should see and alternative day and you should stop at this position. The watch will continue with the same language after this.
If this does not work, then you should be able to find out the day sign after reading the instructions.
If your watch is new and after reading all the literature you still cannot sort out how to make your watch run for a longer period, then contact the maker who should be able to help.
Jan 02, 2011 | Seiko Kinetic watch
My amp kx1200.1 works only 5 minutes and then getting real hot somebody have any idea
You need to swap your main battery for a high performance kinetic... and maybe even ad a small kinetic in the back as well (fused separately) and see how that works for you. Just one oversized kinetic battery replacing your stock battery may do that trick. Remember, its best to install two batteries of the same brand and size, its ok to use the same brand and two different sizes (a kinetic 2400 and a kinetic 600 for example, but with an isolator) but its easier and simpler to just put in a kinetic 1200 or something that will replace your stock power sucking ineffecient lead acid stuff.
Jul 26, 2010 | Kicker KX1200.1 Car Audio Amplifier
Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
Oct 20, 2008 | Seiko Kinetic watch
Cakewalk Kinetic 2 Full Version for PC (3112) Logo
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Anbes
Anbes
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
