Celestial lcd tv
When I turn power on nothing happens
4 Suggested Answers
dodgecharger
  • 254 Answers
SOURCE: LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Posted on Nov 28, 2007
  • 157 Answers
SOURCE: celestial lcd tv LT3200HD needs cold cap board
Replace the caps with 1000mf at 25 volt available at an electronics parts outlet.make sure you put them in correctly.the black line with a -(negative) goes back in the same way you took them out.
Posted on Sep 26, 2009
Testimonial: "thanks for your help that should do the trick."
roety
  • 585 Answers
SOURCE: tv won't turn on
Hi my name is Eric,
I hope I can help you with your issue ,
If the TV is totally dead a voltage test would tell if its the power or mainboard (only two boards in the TV)
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound.
A long time coming on is a classic example of what I am detailing for you below. .
These Samsung LCDs have problems with the power supply capacitors going bad, a servicer will charge between $200 and $450 to repair it replacing either the capacitors or the whole board.
here is a DIY (do it yourself) solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and uf and Volts values)
Samsung uses mostly 1000uf at 16Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
To buy capacitors click here
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
Im am posting a photo of some swollen caps on a board so you know what they look like below
best of luck to you
If you feel good about my solution please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Dec 01, 2009
Technika lcd 32
Probable power supply failure.
Jan 13, 2014 | Televison & Video
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Celestial lcd tv LT3200HD needs cold cap board wont turn on if its too cold it keeps turning off when room temp drops any help would be greatly welcome!
Sep 24, 2009 | Televison & Video
Have a 30" SHARP Aquos LC30HV2U that has a bad power supply. Nothing happens when I turn on the LCD - though it is getting power confirmed by green light going on but nothing on LCD. Visual inspection
You did try the CLEAR button on front of the box?
One possible idea is the cables going the box to the TV. ( might be bad )
If your sure about the problem, you can get your Service Manual here:
http://www.nodevice.com/manual/newmans/upsharp/LC30HV2UPDF/get53718.html
This with have all the schematic, diagrams, part number, and test points you need.
May 17, 2009 | Sharp Televison & Video
Sony Bravia KDL-40S20L1 lcd tv has no power no lights nothing
My Sony Bravia LCD Model-KVL37S400A is not getting the Main Power supply. The LCD is not getting switched on. When i am trying to switch on the set nothing is happening.
Apr 20, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sometimes the sound echos like there is too much bass
I have a celestial Tv.LT3200HD. I cant turn it on. red standby light is working. I have tried remote, on off button on side of tv and turning it off then on. Whats next. There is a gamet of colors in stanby red light when trying to turn it on.
Mar 27, 2009 | LG 26LC2R 26 in. HD-Ready LCD Television
Celestial tv no remote
We have a Celestial TV and the remote has broken - just keep the tv on standby and when you want to turn it on hit one of the volume buttons.
Any ideas on where i could get a new remote - Do you know who the manufacturers of Celestial are?
Jun 28, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
