Question about Sierra Entertainment Emperor: Rise of the Middle Kingdom for Windows
Patches need them
I cant install the Patches for gangland
it's long time since the last post here, anyway I have a problem with this game's patch,
I want to install latest patch which is 1.4
it's said for installing that, these versions are needed :
1.0.2 , 1.0.3 , 1.1.0 , 1.2.1 , 1.2.2 , 1.3.0
I have downloaded and installed 1.1 and 1.2.1
but couldn't install 1.3
seems 1.2.2 is needed, but couldn't find it anywhere, can anyone
May 28, 2010 | Whiptail Interactive Gangland for Windows
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
I have a broadband DSL modem/router in my home office. I also have 2 CAT5e ports there. I want to feed the Internet signal from the router (one of the ports on the back) through a CAT5e point up to my...
Hi Joe,
How are you connecting to the port in the back of your router? if you have crimped a male plug on to some UTP cable then this may be the problem. UTP cable has a solid condutor and needs a different male crimp plug than UTP patch cable, which has stranded conductors.
I suggest you connect the UTP cable between the office and the loft to an RJ45 wall or surface socket in the office, use a terminating tool designed for the make and type of outlet you use, i.e. if using an ADC socket use the ADC termination tool. The sockets are designed for solid cable and have a colour code for you to follow. Then use a factory terminated patch cord between this socket and the router port.
I assume you have terminated the cable from the office onto one of the patch panel ports and want to use a patch cord to patch from this incoming socket to the sockets that are terminated onto the cables going to your other rooms. If you have access to a laptop connect this directly into the router port and ensure you have an internet connection, then plug the patch cord connecting the loft port into the router and take the laptop into the loft and ensure you have a connection at the incoming port on the patch panel. If you get the connnection there then use a factory patch cord to patch to a room you would like a connection in and then take the laptop to that outlet and ensure you have a connection.
If you want to run outlets in multiple rooms without re-patching every time then you will need to have an active switch in your loft and connect the port from the office to this and then patch out of the switch ports to the various room outlets.
Hope this helps.
Cheers, Jason
Apr 27, 2009 | 10 10 Computer Patch panel
Cant play on line
This is from the official websites support forum. Many people have had issues letting the game patch it self. Follow these instructions and you can patch it outside of the game.
Firestorm has no patches available. Tiberian Sun. however, does have one. There are three ways to patch the game.
  • You can run the auto-patch program.
    1. Click on the Start button.
    2. Select All Programs.
    3. Select the Westwood folder.
    4. Click on the game you want to update.
    5. Select Auto-Update.
    6. The game should now automatically patch.
  • If you play online, through Westwood's servers, you will receive the latest update of the game (if one is available) automatically, each time you log on.
  • If you still cannot get the patches you can retrieve them from our FTP site.
    1. Click here to access the ftp site.
    2. Click on the patch needed:
      • TS203 for Tiberian Sun
      • There is a two letter code at the end of the patch this is representative of the language of the patch.
        • ES : Spanish
        • DE : German
        • EN : English
        • FR : French
    3. Select Save in the window that pops up.
    4. In the Save As window make sure Desktop is selected in the Save in: section at the top of the window.
    5. Click Save and the patch should save to your desktop.
    6. Once it is saved to the desktop, double-click on the patch's icon to install it.
Apr 16, 2009 | EA - Electronic Arts Command & Conquer 3:...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Need patch kb959247
Appreciate the direct "Ask Me".
Initially, I tried checking with Microsoft and I was informed that "The Knowledge Base (KB) Article You Requested Is Currently Not Available" pertaining to your required KB959247. Sorry.
However, I checked further and was informed that the actual message is:
"The Windows Vista operating system is not fully up-to-date, and theKB929547 Vista Patch is not present. If you install AVG on your systemwithout the KB929547 Vista Patch, you might experience significantsystem slowdown and internet connectivity issues."
Should this be the case, then what you probably need is KB929547 Vista Patch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 16, 2008 | Microsoft Windows Vista Ultimate Edition
Need patch for free space 2 game to play in windows vista needs to recognize I have 4 gigs of memory
is it not installing,try to browse setup.exe or install file for the game,right click and choose run as administrator..it should be installed w/o any problems,or if you were able to install this and the game just crashes upon playing it,you need to put it to compatibility mode,To do this search for freespace.exe (Probably in C:\Program Files\Volition\", right click and select the "compatibility" tab. Check the box that says "run this program in compatibility mode for" and select "Windows 98"
Sep 29, 2008 | Computers & Internet
Vista patch
download free patches from
www.crack.ms
or seach in google free patch for vista.
ur's kishore chowdary.
Apr 04, 2008 | Microsoft Windows Vista Ultimate Edition
Vista Patch
Simple, most unlikely solution: Try to download patch from microsoft website and install it.
Other Solution: Go to trained professional, (geeksquad or firedog), they will install it more simply and correctly.
Installation of software by them is probably like 30 bucks.
Mar 19, 2008 | Microsoft Windows Vista Ultimate Edition
Need a patch for Vista to install - The need for speed SE 1995
hi lark1,
u need a patch just go to www.crack.ms or www.serials.ws u will get the patch as well as crack trust me.
regards
shailesh
Mar 12, 2008 | Computers & Internet
Sierra Entertainment Emperor: Rise of the Middle Kingdom for Windows Logo
24 people viewed this question
Top Sierra Entertainment Video Game Consoles & Games Experts
James Wishart
Are you a Sierra Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
