Question about Whirlpool RMC275PD Microwave Oven
No lights on control panel, but works fine.
Hi, my microwave doesn't display anything in Control Panel (like ther is no electricity), but it actually works. What is the problem?
  • 61 Answers
There two power supply one for the Magnetron and other low voltage for display drivers and relay.
also it will have 2 fuses one of 10 Amps other for some 500MA replace the second one .
Posted on May 18, 2014
SOURCE: Control panel on a whirlpool microwave
SOME ELECTRONIC CONTROLS HAVE A LOCKOUT FEATURE THAT IS ENGAGED AND DISENGEGED BY HOLDING A CERTAIN BUTTON FOR 5 SECONDS. LOOK FOR A LOCK PAD AND HOLD IT FOR 5 SECONDS TILL IT BEEPS.
IF NOT AVAILABLE, THE TOUCH PAD MAY BE UNPLUGGED FROM THE MAIN P.C. BOARD OR MAY BE DEFECTIVE.
ALSO, TRY UNPLUGGING THE MICROWAVE FOR 5 MINUTES
TO RESET THE MICROCOMPUTER, THEN PLUG IT BACK IN AND SEE IF IT WORKS.
AN ELECTRICAL OUTLET NOT WIRED WITH PROPER POLARITY OR NOT GROUNDED CAN AFFECT ELECTRONIC APPLIANCES ALSO.
Posted on Mar 28, 2008
SOURCE: Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Posted on Jun 16, 2008
SOURCE: Whirlpool MH3184XP-B 2 Black- Will not start, no power, no display
Downstream of the main 20 amp breaker in the upper right hand corner, is a miniture 4 amp fuse in an inline fuseholder. I replaced this and so far, so good
Posted on Jul 15, 2008
tzweeb
  • 318 Answers
SOURCE: Change Fuse Whirlpool Gold GH7155XHS1
no the control does not come off from behind.
what you will find is the top vent grill has to come off first. it has 2 phillips screws that hold it to the top of your unit.
you will find 4 screws on the top, go ahead and take all 4 out and then pull the grill out from the top and hinge outward to remove/ once the grill is off, then there is 1 more phillips screw that holds the control board/ touch panel to the frame. remove and then lift up then out on the panel.
now that you are into the unit, make sure you have UNPLUGGED it first. the fuse is about 1 1/4 inch long white ceramic material with metal ends. you can find a new one at a radio shack or get one online for your unit. r/s has them for cheap and if that allows the unit to run again, great, but...
there was something that caused the fuse to go bad. so dont be surprised if you need a diode or capacitor to fix why the fuse went bad.
Posted on Feb 03, 2009
  • 220 Answers
SOURCE: replace control panel on whirlpool microwave mh1140xmq
There are two screws in the vent cover (grille)that goes across the top remove those and the vent cover and you will see one screw in the top of the control panel remove that one,grab the panel slide it up and pull at the top,it hinges downward toward you and will stay there till you get the wires marked and removed from the board.
Posted on Sep 13, 2009
Testimonial: "TomZS - thanks, you were spot on. Four screws in the top on this model. I was able to get at the control panel. Sadly there was no obvious failure."
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
My smh8165 microwave stopped working and the display says "SE" and is less then a year old
Unplug microwave. Remove (2) flat head machine screws on the top of the microwave holding in the top front trim. My trim slid left and gently pulling was removed. The control panel has (1) screw holding it in. Remove screw, slide up and gently pulling detach from microwave. There are (5) electrical disconnects which need to be disconnected. Do not force they should come easily. Lay control panel on and old towel. Squirt both the male and female connections(in microwave control panel opening) with electrical cleaner. Carefully clean up excess. Connect the (5) quick disconnects and carfully fit back in the control panel opening. Attach screw. Place top trim in and slide right to lock. Once it is in secure the top two screws. Clean area and plug back in. Hopefully your up and running. These pieces break real easy so don't force anything.
May 26, 2011 | Samsung Microwave Ovens
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
Hi.. the LED display has only 2 vertical light strips that glow. If I enter the time I can just see it on the display but still only the 2 vertical plus the 2 dots actually light up. (Sharp R340...
I regularly repair these controller assemblies for $54.95, which includes insured return shipping.
The service manual is at my site here:
http://www.microwavecontrol.com/r340dk_r340dw_sm.pdf
Feel free to contact me directly for all you need to know to remove and ship the controller assembly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Dec 08, 2017 | Sharp R-340 Microwave Oven
665.68601890 Acts as though it is not receiving power but breaker is not thrown. Is there an internal reset. Nothing responds - no lights, fan or microwave. Panel is black and non responsive
ther is on most microwaves a fuse inside usually located behind display panel located in a fuse block or will be on the control board itself.. normally a 20 amp fuse...try that first if not then make sure you have power to control and if so and no display most likely the display control board...
may luck out and be just the fuse though....good luck
Jan 08, 2011 | Kenmore Microwave Ovens
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Sharp microwave r630ds
The problem is in the display control unit mounted in the outer door panel.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 23, 2007 | Sharp R-630D Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
