Will not spin or rinse; timer advances slowly
Frigidaire Affinity ATF6000FS1 front loader will not do a rinse or a spin cycle. Timer does not seem to work right either. Advances one minute about every five. Will not leave the wash mode. A thirty minute PP load went 45 minutes without ever going to rinse. Tried doing a spin only but just made noise. Tried unplugging and plugging back in and still did not work. During the 45 min wash the time went to "Pause" and door unlocked. After waiting about five minutes I pressed the start button and wash cycle continued. There seems to be no resolution to this. Repair could be costly. Thinking of going back to old fashioned top loader as this machine has had a mold problem ever since I have owned it no matter all the precautions I have taken. Not sure if machine is worth the price of fixing. Sounds like an electronic and/or mechanical problem. Ideas? Thanks
  • 213 Answers
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Posted on Nov 20, 2007
  • 1294 Answers
SOURCE: HE3 Front loader Controls Locked
Try 'end of cycle' pushed down till the light goes off. Or locate the button with diagram of 'lock', & push down till the light goes off.
Posted on Mar 16, 2008
SOURCE: Inglis Washing Machine agitator not working right
replaced timer problem solved thanks
Posted on Mar 30, 2008
esbee0522
SOURCE: Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Posted on Jun 19, 2008
ngfam1
  • 639 Answers
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
The timer on our front loader is moving very slowly, and the tub is not spinning
HI, this is a defective timer motor. have it replaced asap. A defective timer can disrupt the wash cycle, and even stop it as well. this will also effect the efficiency of the unit as well.
Aug 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Have to change cycle manually
Reason? There shouldn't be one. Seems you're extraordinarily unlucky with timers. Mine's 10yo, never broke. The timer is a standalone part, it's not dependent on any other parts for its longevity. So there can't be any other parts in the washer 'killing' it.
Are you handling it gently? Turn it slowly when setting, don't whip it around.
Jul 03, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
