Question about Samsung TXH1970 TV
No picture on tv
I have satelite TV. When I turn on the tv I have the word "video". When I try to program the tv I can't get any channels.
    Sergeant:
  • 227 Answers
Have to select antenna, video is for when you use a vcr or DVD input. Otherwise Video means you are using another source to dump into your set that you want to watch froma pre recorded source.
Posted on Jun 15, 2009
I just bought a progressive scan Tv and can't get it to srtup to any channel it just stays on channel 3 mono
Progressive scan has nothing to do with your tuning, it refers to the scan lines in laying the picture on the screen...ie. progressive scan versus interlaced scan.
to program TV channels you will need to go into the menu to do that either automatically or manually. If you have a cable or satelite box connected to unit, that may explain why it programs to only ch 3.
If using cable or satelite box I highly recommend use of Either HDMI cable or composite cables.
Apr 07, 2014 | Televison & Video
I have did the auto scan and the tv screen is still blank. i need some answers asap please!!!!!!!!!!
does a DVD player work on the unit?
if so, be sure you have good connections of your input cables (and you know these connector cables to be good), then see if you can manually program channel 3, or any other channels programmed manually. I suggest channel 3 in case you are using satelite or cable box. Then turn the cable or satelite box & see if you get reception on channel 3.
Apr 01, 2014 | Televison & Video
The screen is blue. channels come up but no
Are your sure you're on the right channel (3/4) did you try the video inputs? ie. use video out from Satelite to video in on tv and select the video input on the tv
Sep 30, 2009 | Apex Digital AT2002S 20" TV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
No signal
LOOK N THE MAIN MENU ON THE SATELITE CONVERTER BOX LOCATE WHAT CHANNEL TV IS PROGRAMMED TOO TUNE TV TO THAT CHANNEL WILL EITHER WORK ON AIR OR CABLE
Dec 13, 2008 | Televison & Video
RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Nov 14, 2008 | Televison & Video
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your tv.you cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
wg
Jan 28, 2008 | JVC AV-27D202 27" TV
Picture goes Black
that is easy one go to options menu on video look for cc or closed caption option and turn that off
Jan 12, 2008 | Hitachi 43FDX01B TV
Programming
can you enter channel 4 manually and get picture
Nov 19, 2007 | Zenith Z19A11S TV
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
Samsung TXH1970 TV Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
