Question about Toshiba Computers & Internet
Always restart after loading OS . thus this a problem with power ?
4years old laptop from on hand
  • 56 Answers
The chances are very less. Does it show any error messages..like "Boot loader missing"..then you should reinstall the operating system.
else download a boot mode antivirus software and scan your computer with it. use this link to dowload :
Posted on Apr 07, 2014
Powers up but will not load either the bios or OS , powers up three quiet beeps then restarts...
Wiil be the memory is not correct or , will be need the setup of this laptop and the specifications , apply one reset the BIOS
Sep 17, 2013 | Medion Computers & Internet
My son was watching a movie through a usb memory stick on his eee pc r101d. he pulled the stick out while the movie was playing, now netbook will not restart. I tried system repair, files loaded half-way...
Sounds like a critical system file was damaged. If the system repair fails (also safe mode), as a lastg resort you can always re-install Windows over the existing installation. Don't format the disc and you will find all of his old files in C:\windows.old
Aug 12, 2011 | Computers & Internet
RESET APPLE LAPTOP
You can either do a soft or hard reset. If u find no go even after the reset, You can reinstall the OS if i like to do so.
Soft reset
  • Close all applications.
  • Click on the apple in the upper left-hand corner of the screen. Select "Restart" from the menu.
  • Press restart button located on the upper right-hand corner of the keyboard. Your computer will turn back on.
  • Hard reset
  • Press the power button located in the upper right hand side of the keyboard, just above the eject button.
  • Continue to depress the button for 10 seconds. The computer will power off.
  • Press the power button again to turn your laptop back on.
  • Oct 09, 2010 | Computers & Internet
    My dell inspiron 1525 has a black screen with a white cursor showing
    First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
    1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
    2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
    3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
    4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
    5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
    Dec 10, 2009 | Dell Inspiron 1525 Notebook
    Dell Inspiron6400/E1505 restarts automatically after shut off
    The problem of your laptop is that once it has been attacked by a virus. In that very case that virus may be removed but the damage it has made to your OS cannot be restored unless you format your laptop with Windows XP/Vista.
    Or next best reason may be problem with your laptop RAM.
    You should quickly consult a good hardware engineer for sough ting your problem out. Bye
    Feb 23, 2009 | Dell Inspiron 6400 Notebook
    I need installer drivers of target sound ac'97hda
    sir,
    i am using reinstalation original cd which i have purchased with second hand old used computer. i have got 25 digit key with this but after installation on taskbar appears a key that 30 days left for activation. asking 42 digits confirmation id no. which not possible to get with second hand 4years old computer. so please try if possible.
    thanking you,
    Dec 04, 2008 | Microsoft Windows XP Professional
    Acer aspire 5715z/5315, turned laptop on took time to load up wasnt responding,restarded laptop then it wouldnt restart then i turned it of manually, turned it back on,screen acer back ground in the bottom...
    Reboot your system-press and hold F8 until you get a list of options-select Safe Mode-enter.Your system will run in Safe Mode,giving you a dropdown list as it progresses-check where it stops.In this way you can establish wether you have a corrupted or incompatible driver and which {Graphic ie} stop the system.You will have to reload the OS to solve the problem.If you cannot even boot into Safe Mode,your drive very likely crashed.Happy landing.
    Jul 22, 2008 | Acer Computers & Internet
    Constant hourglass symbol on blackberry
    Don't reload the OS. There are easier options. When this happened to my pearl I did the following until it worked.
    1. Power off then on. No success.
    2. Power off with batter out then power on. No success.
    3. Deleted extra pictures to clear up some memory. No success.
    4. Deleted the Facebook application I installed a couple of days ago. And did a manual restart. No success.
    5. Deleted another application that had been installed for about a year but this time let the OS do it's own requested restart to fully uninstall. SUCCESS!!
    All along I suspected it was the Facebook application trying to push updates. I deleted memory to clear up space if that was the issue. That wasn't. When I deleted the application I should've let the OS to the requested restart. The only reason I deleted the additional app was so I would get prompted again to do a OS restart.
    After restarting, I got a handful of old facebook messages sent to my phone even though the app was no longer there. I deleted the messages but my new problem was that the indicator light was still blinking to show I had new messages even though I didn't. Another power off with battery out finally fixed the whole thing.
    It seems like a lot of steps but this was much quicker and easier than reload the OS and losing all my apps.
    Apr 12, 2008 | RIM BlackBerry 7250
    Bios Problems
    Do you have an extenal monitor you can plug in to the back of your laptop and try that out. May be just the Lcd try that and let me know if it comes on and you have a screen that works, Then we can go from there, Don't be afraid to come back here and ask me. Ok hope that gets you going . And sorry about your problems, Try and have a good day...
    Jan 06, 2008 | Toshiba P25-S670 Notebook
    My pc problems
    Maybe something is wrong with your power supply. If power supply get old, it will restart the computer by itself. Try to borrow a friend's power supply and test it out.
    Nov 09, 2007 | PC Chips P23G Motherboard
    Computers & Internet Logo
    56 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
