Question about Comfort Products Relaxzen Deluxe Padded Microfiber Massage Recliner Brown Microfibre Recliner
Damaged goods The base is broken, and the axle tree is stuck inside, the chair is useless with out the base obviously so I need to get it fixed otherwise its just an expensive broken chair. Also the massage and heating no longer works, I'm not sure what happened their. This chair has excellent reviews and I hope you will get back to me so that I can return to enjoying it, thank you and have a pleasant morning/afternoon/or night
  • Joel Martin
    Joel Martin Mar 25, 2014
    just in case the only email I check is joelmartin1995@ymail.com, and thanks again.
    Top Expert:
  • 80,339 Answers
Sorry we do not have repair facilities.
Posted on Jul 21, 2017
I have a black and decker 1179/100 drill. The drill was dropped and now will run only in reverse but not forward. I took a look inside and nothing was obviously broken. What would cause this?
Obviously, the switch which controls the direction in which the motor turns the bit is either damaged or stuck. I believe I'd call B&D technical support. The fix may be something simple.
Jul 28, 2017 | Decker Drills
Re cliner foot rest wont open need digram to fix
How to Fix a Reclining Lounge Chair - DIY Recliner Repair ...
? 2:28
https://www.youtube.com/watch?v=0P4cHbjiJmc
May 29, 2012 - Uploaded by How to... Science, Craft Plus Other DIY Fixes
Is your footstool not working / not rising up? ... How to Fix aReclining Lounge Chair - DIY Recliner Repair - Fix a Broken Plastic Foot Stool Lever ... Hi there any ideas on how to fix the back of the recliner its stuck in open position? I have removed it and the steal bars that the back attaches to wont align ...
Recliner Mechanism - YouTube
Dec 19, 2015 | Health & Beauty
My aspire powerchair quit and the first 3 battery lights started blinking, what does this mean?
There are thermal fuse under the chair where the batteries are . This is to protect the motors from overheating and ruining them . The fuses are availible on ebay or any medical supply store that deals with wheel chair . I replaced the ones on my mother - in laws Chair and anyone who has a little mechanical ability can change them . They were $10 Each when I replaced hers last December . It is alot cheaper than the motors . That is why they are made that way . Good Luck !!!!!!!!!
Hope this helps!!!!!!!!!!!!!!!!!!!
Aug 16, 2014 | Health & Beauty
Chair is stuck in a raised position
Hello. The chairs lift needs to be cleaned from the inside and the hydralic fluid changed.
Apr 18, 2014 | Flight Dental A10E Patient Chair
Office chair lowers on its own
It will be one of two things, either the gas strut is no good and in this case you might as well get a new chair. Or the lower lever is stuck in the " lower" position, if this is the case freeing it up should cure your problem
Aug 28, 2013 | Furniture
Hoveround operates only in circles
You may either have have a bad motor on one side or one of the keylocks/keystops holding the wheel on the axle has broken. Check to make sure that both of the manual brake levers are in the UP position (inside the opening above the footrest, between the rider's ankles).
If it is a motor that needs to be replaced, they run around $600 plus labor, you will need to contact Hoveround to register the power chair with the serial number (found inside the manual brake opening above the footrest) and make an appointment for service.
If it is a keystock, they can be mailed to you from Hoveround for just a few dollars, sometimes for free if there happen to be some laying around the call center.
Have someone watch you operate the chair, or tip it backwards to raise the drive tires up so you can see if both axles are turning or not. If one axle is NOT turning, you have either a blown motor or possibly a connection to the junction box has come loose, which would be indicated by blinking lights on the controller. If both axles are turning and no lights are blinking, then most likely the key stock has broken and the drive tire just cannot lock on and get a grip.
I hope this information is helpful, good luck!
Dec 16, 2010 | NRS Hoveround MPV 5 - Used Power...
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
I have a 1997 Jeep Grand Cherokee with a 5.2. I am experiencing problems with the 4x4. The front Drive-shaft spins however its not making the front tires turn. What could cause this?
If the driveshaft is turning then you need to check both axles to see if they turn. If you see that an axle is turning but the wheel is not, you have a broken "u" joint or c/v joint (I think either was available on that year.) If neither axle is turning then likely you have broken some gears inside the differential. To verify that remove the cover on the diff and look. Broken gears are obvious and you do not need to be too experienced to see the damage. Gear damage is expensive to repair and you cannot do that work yourself. You can replace an axle or the entire differential, end to end. Instructions can be found for axle and complete diff replacement in both chiltons or haynes manuals. Or you can try it without instructions ans ask me if you need help with any part of the job.
Sep 13, 2010 | 1997 Jeep Grand Cherokee
NEED A REPLACEMENT BASE FOR MY OUTDOOR SWIVEL/TILT CHAIR
What is the make and model of your outdoor swivel chair? You can order parts through this link below, otherwise, please let me know so that I could assist you further:
http://www.thefind.com/furniture/info-swivel-chair-replacement-parts
Sep 10, 2010 | Garden
Loud growling noise from drive wheels when in motion
It sounds like you may have bad bearings in the caster wheels; replace them and see if that solves the problem.
Jun 28, 2010 | NRS Hoveround MPV 5 - Used Power...
Comfort Products Relaxzen Deluxe Padded Microfiber Massage Recliner Brown Microfibre Recliner Logo
2,666 people viewed this question
Top Comfort Products Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Comfort Products Furniture Expert? Answer questions, earn points and help others
