Question about Schiller Cardiovit At 1 Ecg Machine
The different between a mac 5500 and schiller at 1 machine
What is the diferent?
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 | Medical
Schiller at-1 says lead off
Check the leads. If any of the Leads is open the this problem can occur. You have to check the continuity of each cable for the lead end to socket. All leads should show a resistance of 10KOhm
If you wish to get some details About schiller AT1; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 28, 2013 | Schiller Cardiovit At 1 Ecg Machine
Can a Schiller AT2 ECG paper size ( 8.5 * 11) inches be used on a GE MAC 1200 EKG machine?
hi,
Both machines uses the same dimension paper ( 8.5 * 11 Z fold paper ). You can use the paper in GE MAC 1200 EKG machine.
ok
Sep 27, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
How do you set time and date on schiller at2 ekg machine
HI,
To set time on the schiller AT2 do the following.
1. Power ON the machine.
2. Press the following key sequence ALT,9,1,1.
3 Now enter the time using the digit key (HHMMSS)
You will hear the conformation beep indicating that the time is seted.
To set the date on schiller AT2 Do the following.
1. Press the following key sequence ALT ,9,2,2.
2. Enter the date using the digit key (DDMMYY)
You will hear a conformation beep indicating that the date is seted.
ok
Sep 08, 2011 | Schiller Welch Allyn Cardiovit At 2...
My AT-2 plus EKG suddenly stopped transmitting from the electrodes, i.e. all the leads show flat line. My e-mail is alaronov@mac.com
hi,
You have to check the patient cable of you machine first. you have to check the LF (left foot ) lead of the cable. if there is any other cable you can try it with that. if there is any other ecg machine you have which has the same connector. then try with that also. if the cable found faulty then replace it. Is there is any trace ( line trace ) in the paper for lead 1 to v 6 if not , the problem is with thermal printer of you machine. if so you have to contact the nearest schiller authorized service center. Because the thermal printer head is not available in the open market.
ok
Mar 31, 2011 | Schiller Welch Allyn Cardiovit At 2...
The schiller at-1 ran out of paper, I put some more in. Now it will not print any suggetions?
HI,
check the paper u have inserted. it should be Schiller original paper with page marking. also clean the paper sensor. u can see the paper sensor near the side of printing head. a small square portion. clean it with an ear bud, don't use any solution for cleaning only ear bud.
ok
Nov 14, 2010 | Schiller Cardiovit At 1 Ecg Machine
I have Schiller AT-2 Plus, i need instruction
press Alt then 9 - 1 - 1 for the time.
press Alt then 9 - 2 - 2 for the date
May 09, 2010 | Schiller Welch Allyn Cardiovit At 2...
Schiller AT-1
check paper alignment
maybe papermark sensor problem also
Oct 16, 2009 | Schiller Cardiovit At 1 Ecg Machine
ECG Schiller AT1 shuting down in work
Most likely needs a new battery. Can be ordered from R&D batteries.
Apr 08, 2009 | Schiller Cardiovit At 1 Ecg Machine
Schiller AT-1 ecg not printing.
Turn on machine, wait a few seconds then press ALT-0-1-1
You will get a print out showing all the settings
Feb 16, 2009 | Schiller Welch Allyn Cardiovit At 2...
Schiller Cardiovit At 1 Ecg Machine Logo
43 people viewed this question
Top Schiller Medical Experts
Electro Med Services...
Are you a Schiller Medical Expert? Answer questions, earn points and help others
