Question about RCA L32HD31 32 in. LCD HDTV
Rca l32hd31yx12 green yellow led turns on no picture no sound
Led looks green maybe yellow stays on. no other nothing else appears to work. no visable scorch marks or burn smell on anything inside. got for free.
SOURCE: My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Posted on Apr 09, 2009
circuitworld
  • 335 Answers
SOURCE: rca 32 screen turns on but stays black
Theres no start-up signal being encoded, this means the interface board has an offset capacitive value. You need to test and measure the capacitors and npn/pnp transistors, along finding some open diodes too on the main board (interface). You have to test the capacitors under their operating voltage also to see at which point their breaking down. The problem is a 'load' condition on the main board. You can repair the board if your savy and you have test equipment or you can just replace the board. If you want to replace it e-mail me and I'll help you out....
Posted on Nov 25, 2009
mpaint
  • 36 Answers
SOURCE: RCA L42WD22YX5 TV green light but no sound/picture
Recommend opening it up and looking at the power board and see if there are any visible Bulged or leaking capacitors.
Bad caps are a major source of computer and LCD no post problems.
If you find em, then just find replacements with the same uF and voltage and solder them out/in.
Posted on Jun 28, 2010
budmrtn
  • 11361 Answers
SOURCE: i have a Rca#L32HD31Yx12,Serial#I256CNo82. ok,
You may have bad T-CON board, see my guide here to see if you vae the same problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Jul 30, 2010
palaboy
  • 5807 Answers
SOURCE: I have a RCA L32HD31YX12.
Thanks in advance for choosing Fixya for assistance.
I would like to make a clarification request , before I present my possible solution to
your problem,
Does it happen on all TV inputs ? or just on the tuner?
Have you tried connecting the TV audio out to your AV Receiver or similar just
for initial troubleshooting?
If it happens to produce sound on your AV receiver , then Congrats...
you have just troubleshooted a large percentage on electronic circuits
inside the TV ( even without opening it up ).
I can post further , while I await for your answer , to resolve the problem
you are having and post if you can further DIY ( inside the unit )
Posted on Oct 09, 2010
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
HI, I have a RCA Model: L32HD31YX12 TV and when i plug the power and cable into it all I get is a black screen. The green light at the bottom of the TV is on but I'm not sure what to do. Also I do not have...
I have an RCA LCD TV Model#:L32hd31yx12. I have an issue with the settings staying in place when I shut it off then turn it back on I have to reset everything. Is there an update for the firmware for this particular tv???
Dec 26, 2010 | Televison & Video
Dec 28, 2009 | RCA L42WD22 42 in. LCD Television
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture no sound
First check to see if you have any voltage at test points with a digital meter.
You may need a repair manual for this.
Since you hear some noise your main fuse is ok.
Try checking this tp voltages first.
BE CAREFUL, wear gloves
Feb 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA L32HD31 32 in. LCD HDTV Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
