Question about Samsung Televison & Video
How do I fix having lines on screen of samsung television?
Screen
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
How do you fix samsung ps50a457p1dxxu has black verticle line down centre of screen
A vertical line could indicate a faulty lower scan (long skinny boards along the bottom of the set) board, a faulty lower scan connection to the screen or a bad screen altogether!
Jun 08, 2014 | Samsung Televison & Video
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung PS50Q96HD had coloured vertical lines on the right of the screen. An engineer from Comet came had a look at it and said it was the screen which can be replaced for aroung £500.00 nearly the...
The colors vertical lines on the tv are more 3 or 4 lines,not worth fixing,he porobally right the screen is dead,not.Take the Samsung authorised offer,because it there products,the 90 Euro refuned,it great,if repair have to be made.
Jul 03, 2010 | Samsung LTN1535 15 in. HD-Ready LCD...
Colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
Dec 01, 2009 | Samsung LNT4066F 40 in. LCD Television
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Convergence
if the blue lines runs across the screen in the center its a vertical deflection problem it will need to be diagnosed.
Oct 02, 2008 | Samsung HC-P4752W 47" Rear Projection...
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
SAMSUNG HCM4216W has a verical line
the vertical line has nothing to do with the picture tube,Some component in the horizontal circuit is causing that problem,most likely an electrolytic capacitor
Dec 07, 2007 | Samsung HCM4216W 42" Rear Projection...
Open Questions:
Televison & Video Logo
12 people viewed this question
Jerry Greenberg
Jerry Greenberg
