Question about Dahle 20330 Small Office Level 5 CrossCut Paper Shredder
Omnitech ot-nxc 10pa won't turn on
Wont turn on
My Omnitech 12 sheet shredder is barely 6 months old and will not even turn on.
check the warranty period and if within that period take it back for warranty repair or a new one
Dec 20, 2015 | Omnitech 12 Sheet Cross Cut Shredder
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Is there a sensor for Omnitech shredder OT-NXC18PA? if so where can I locate it?
I have this same shredder and same thing happened to mine just 2 months after warranty is up. I called the company and told the sensor is gone and there is no way to replace. BTW mine runs in reverse but not forward.
Jun 24, 2012 | Tech Solution Office Equipment & Supplies
I have an Omnitech 2gb mp3 player. I have used it previously, as previously as a couple hours ago. I uploaded new music and removed it from the computer, but now it won't work. When I turn it on, it is...
Did you checked that a the HOLD function is not enabled ?
It is a button on the player, allowing you to "block" the player in case of unintentional buttons pressings.
Sep 25, 2011 | Computers & Internet
I have an Omnitech OT-535BL paper shredder. It got a jam, I cleaned the paper out but it still wont work. It sounds like it is turning on when I plug it back in but it wont go.
This unit can also overheat and automatically shuts down when it does; to be thorough--simply unplug, empty the wastebasket, turn upside down, remove any remaining paper from blades, plug back in, and leave it alone for 30-60 minutes. Try again.
It's not an industrial shredder and has a low daily capacity, designed only for small office use.
May 02, 2008 | Computers & Internet
How to make a call via OT-020C blue tooch
I have a OT-020C BT headset and once paired to my Sanyo SCP-3200 phone, I tap the power/control button on the headset and say who I want to call. The voice-recog in the phone does the rest, usually. Of course it doesn't work in noisy areas so then press [END] and manually dial the number.
Apr 08, 2008 | Samsung SCH-i600
Dahle 20330 Small Office Level 5 CrossCut Paper Shredder Logo
Top Dahle Office Equipment & Supplies Experts
jhnolson
Dennis Key
Dennis Key
Are you a Dahle Office Equipment and Supply Expert? Answer questions, earn points and help others
