Pharmacia electrophoresis power supply eps 500/400 manual
I have a dell dib75r pinevalley mainboard I need to know whats the max power supply i can apply to this motherboard pls. for graphics card
The stock 305W power supply guarantees 20 to 25W on the +5VSB rails and 150 to 170W on the 3.3v/5V Rails. Many GTX 750 TI now say (300W PSU that can supply 18 AMPS MIN on the 12v rail aka 216W on the 12v rail.
Many EPS 12v power supplies only guarantee 10 to 15W on the +5VSB and 125 to 130W on the 3.3v Rails.
This means you buy the supply and it may not even turn on. If it does it wont work with the 960 card installed.
Buying a power supply is not a single 12v rail and thats the only thing it uses.
There are many users who should have gotten a corsair RM1000 but instead chose an ATX not EPS 12v power supply at 500 to 750W and they have the Solid Amber Light of *****. EPS12v 2.92 for 750W and up guarantees 150W on the 3.3v rail, 20W on the +5vsb rail and 375W on the 12v Rails minimum.
CORSAIR RM Series RM1000 1000W ATX12V v2 4 and EPS 2 92 80 PLUS GOLD...
Jan 20, 2016 | Dell Computers & Internet
Hi I need the service manual for pharmacia lkb eps 500
Hey, I have a 220V version. If you want I can send you some pics, well, if you didn't already fix the problem!
Apr 16, 2013 | pharmacia Lkb, Model Eps 500/400 Power...
New GA-990AX-UD3 motherboard will not boot
You really should take that Power Supply, and use it on grandma's computer.
The 8-pin EPS +12 Volt power cable was brought out, to provide more power To the motherboard AND processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
The 4-pin ATX +12 Volt power cable has TWO yellow wires.
Yellow wires are 12 Volt wires. (And two Black ground wires)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The 8-pin EPS +12 Volt power cable has FOUR 12 Volt wires.
In the motherboard manual, does it say, "Yes Tom. Go ahead and use a 4-pin ATX +12 Volt power cable. We don't care. We just use an 8-pin EPS for fun."
[ This is an 8-pin PCI Express power cable. Completely different,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8 ]
The motherboard probably uses 150 Watts by itself.
No Ram Memory, no CPU, no fans, etc.
The CPU could use up to 125 Watts of power. Just depends on what AMD, socket AM3, processor you are using.
Now to graphics card's power;
The most Wattage a PCI-Express x16 slot can deliver is 75 Watts.
The most power a 6-pin PCI Express power cable can deliver is 75 Watts.
8-pin EPS +12 Volt power cable? 150 Watts.
When buying a Power Supply you should calculate all components needing power,
http://extreme.outervision.com/psucalculatorlite.jsp
,then buy a Power Supply that has AT LEAST 10 percent more power than needed. Easier on the Power Supply.
Also a computer will NOT use more power than it needs.
10,000 Watt power supply, (Exaggeration ), and the computer only needs about 100 Watts for surfing the internet?
Computer ONLY uses 100 Watts.
Due to the price, the above, and the availability, you should use a 500 Watt power supply at least.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=899123&CatId=1079
http://www.amazon.com/StarTech-6in-Pin-Power-Adapter/dp/B002O21XHQ
Or use it on yours if it has enough Wattage.
Back in the day, the motherboard didn't need to supply that much power to components on it.
More powerful Processors, Ram Memory, and graphics cards, brought the power needed, up.
A 4-pin ATX +12 Volt power cable was added for the motherboard. Then 6-pin PCI Express power cable for graphics cards. Then the 8-pin PCI Express power cable for graphics cards. Lastly the 8-pin EPS +12 Volt power cable.
(Better make sure the Power Supply you have is good, if you wish to use the above power adapter cable. Nothing like having a Power Supply with a weak voltage power rail, and a new build, to pull your hair out on )
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
Out of the motherboard manual Page 23,
"With the use of the power connector, the power supply can supply enough stable power to all the components on the motherboard. Before connecting the power connector, first make sure the power supply is turned off and all devices are properly installed. The power connector possesses a foolproof design.
Connect the power supply cable to the power connector in the correct orientation. The 12V power connector mainly supplies power to the CPU. If the 12V power connector is not connected, the computer will not start.
To meet expansion requirements, it is recommended that a power supply that can withstand high power consumption be used (500W or greater). If a power supply is used that does not provide the required power, the result can lead to an unstable or unbootable system."
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2012 | Gigabyte Technology GA-990FXA-UD3-...
Technical manual for pharmacia biotech ultrospec 2000
my pharmacia biothec ultrospec has no carousel rotating which i got only from an auction, is there really any model with only one cuvette slot and which does not rotate? if not, where i can but this carousel type accesories for the said spectrophotometer, any technical manual pls?
Feb 16, 2012 | Air Purifiers
Where can I download service manual for Minolta pro ep 2030. Free if possible
i can download it for you send me an email to forward it to you
Jan 31, 2011 | Minolta EP1083 CS/PRO Copier
Mustek EP A3 What power supply do I need for this?
Mustek EP A3, power supply input range is 100 Vac~250 Vac, 47~63 Hz, power consumption is 1.0 A, 15 V.
YBC (/\)
Nov 09, 2009 | Mustek TwainScan 600 III EP Plus Flatbed...
Redundant hot swap psu's to EPS 12V (24-pin) ATX Power Supply
rpi.jpgthis is the psu
zalman.jpgthis eps 24 pin
as u can see the matter at hand can be preformed, as long as the fitting is compatable
Jan 29, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
