Question about Mazda Vehicle Parts & Accessories
What is a ecm
Truck will start but wont turn over
    Sergeant:
  • 462 Answers
Electronic control module
Posted on Sep 07, 2014
Pulled the ecm fuse while car was running now it wont start .
Year/make/model???? Pulling this fuse will cause the ecm memory to be erased. You may have to hold your foot on the gas pedal somewhat and coax it to start and get it running so the ecm can perform a relearn.Not a wise idea to pull this fuse. Worst case scenerio is internal ecm failure
Nov 07, 2015 | Cars & Trucks
Wont turn over wont boost ap hand goes to 0
With limited info I would say starter is at fault. That would would account for no boost from outside source and when turn key the volt meter goes to zero.
Apr 18, 2014 | 2004 Chevrolet TrailBlazer
Ecm light on turns over but wont stat
Did you also change the timing belt? Could be a timing problem, or even compression
Feb 03, 2014 | Volkswagen Passat Cars & Trucks
Dodge Nitro ECM diagnosis
Are you getting spark on any cylinders ?
Apr 13, 2017 | Dodge Nitro Cars & Trucks
Ecu box passat
ecm goes bad it will go in limp mode, vechicle will run poorly check engine light will stay on vechicle wont start.you need to use a code scanner check for ecm fault code, if check engine light not turning on when you start vechicle could have blowed ecm fuse or wiring problem, could have loose connection at ecm electrical connector or ecm getting poor ground but first check for a defective ecm using a code scanner.
Jan 23, 2012 | Volkswagen Passat Cars & Trucks
Service engine light no longer turns on when key is turned and car wont start
ck fuses, either ecm does not have power, or the ecm maybe bad.
Jul 05, 2010 | 1995 Honda Accord
Mustang wont start check engine line shows up but wont turn over battery is bran new starts for 2 mins then stals then wont turn over no more think its ecm but its starts somtimes
Try this website to download a free manual
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
May 01, 2010 | 1994 Ford Mustang
Turn over but wont crank up
check your E.C.M. fuse, then you could have a bad E.C.M. or coil packs on the vehicle
Oct 26, 2009 | 1998 GMC Jimmy
94 jetta fuel pump wont work
Check your ecm relay I had one go goofy on my 1994 Passat it controls power to the ecm modual the car will turn over but will not start it should read 109 on the top of the relay I replaced it in my passat and it fired right up and I havent had a problem since
Feb 09, 2009 | 1994 Volkswagen Jetta
Vehicle Parts & Accessories Logo
16 people viewed this question
Top Mazda Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
David Burbee
David Burbee
JOHN LAPIER
Are you a Mazda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
