Question about Maxtor Hard Drive
Hard drive instalation
i,m trying to install a 40 gig samsung hd as a slave to a maxtor hd primary and cant get the computer to open except on the setup page and it tells me that the primary is not installed what do i do
  • 3 more comments
  • Anonymous Nov 08, 2007
    I need to know the jumper settings to install my new hard drive as a slave
  • Anonymous May 26, 2008
    Capasitor in power supply blew but after replacing power supply it wouldn't boot. Bought a used computer and wanted to use the old ;hard;drive. Wanted some info on the pin assignment.
  • Joe McCammon
    Joe McCammon May 26, 2008
    I have a Maxtor 5A250J0 250GB trying to make a slave on a Dell VPS B600 r
  • Anonymous Jun 03, 2008
    want to know the jumper settings, slave and master for maxtor 91360u4
  • Anonymous Oct 30, 2008
    I need the jumper settings for a Maxtor Hard Drive to slave it to another Hard Disk please.
  • 63 Answers
To slave the Maxtor you remove the jumper or jumpers
Posted on Nov 20, 2008
  • 1,006 Answers
Witch computer do u have?
Laptop or DESKTOP PC?
Posted on Oct 30, 2007
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
How do you pin a maxtor 40 gig hard drive? I want toi jumper it so it runs continuus withe the 40 gig hard drive I have with a operating system or how do I have two operating systems in the same computer I...
If you are using the older style hard drive, the main drive will be the master and the other the slave. The master has the pin up and down in the middle position and the slave should be the second to the last on the right when looking at it from the back. There should also be a diagram on the top of it. Double check me though, just going by memory. I know you are aware but.....make sure the computer is off and don't forget to plug in the power plug. The computer should "find" it on boot up and give it a name, probably D or E.
Nov 19, 2009 | Computers & Internet
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I want to install the Maxtor 32049H2 N256 as slave Hd in my new computer how do I set the jumpers ?
hi frnds... step by step way are following link
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/
or
http://www.easeus.com/resource/install-ide-hard-drive.htm
Apr 25, 2009 | Maxtor Hard Drive
I have an old maxtor hard drive 40 gig, nad my PC couldn't recogn
just need to set the jumper so this will work as the slave
Apr 18, 2009 | Maxtor Hard Drive
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Problem maxtor hard drive
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
Nov 26, 2007 | Maxtor Hard Drive
Maxtor Hard Drive Logo
852 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
