Question about Uniden Computers & Internet
Ubr243 trying to connect to computer but I don't have the cd.
My computer says I don't have drivers for my camera after running the CD.
You don't need to use a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 24, 2012 | Fuji FinePix A340 Digital Camera
I don't have the installation cd for an LG CDMA usb modem-where can I get one?
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ? you will need to update or install the driver
http://download.cnet.com/lg-cdma-usb-modem/3000-2109_4-66208.html
hope this helps you
Feb 26, 2012 | LG Electronics LG CDMA USB Modem
I don't know of how to conect my webcam
whatever webcam you have first connect it with the computer then insert the installation cd and install the drivers when its done take the cd out and restart your computer and its done
Jan 03, 2012 | Computers & Internet
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
Oct 10, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
I don"t have a cd - rom
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 27, 2010 | Canon PowerShot A460 Digital Camera
Why can't i connect my ipod touch to my cd player
because the white ipod cables don;t have enought wires to trasfer the data
you need the ipod interface for the radio
Mar 28, 2010 | Blaupunkt London MP37 CD Player
I DON`T HAVE A CD DRIVER FOR COPY OF VEDIOS TO COMPUTER
If your camera uses firewire connection it seldom comes with a C.D. just pluging in the camera to your P.C should activate the program it requiers.
One needs a movie maker program to copy movies from the camera on to the P.C.Try windows movie maker. If not try to download one from th web
Mar 12, 2010 | Panasonic NV-VZ55 Camcorder
I need to install my printer to my computer but i don can
Try this. Before connecting the printer put the printer driver cd in the drive and install the drivers. If not asked to connect the printer, then restart the computer with the CD in the drive Connect the printer. Printer will be detected.
Dec 17, 2008 | Office Equipment & Supplies
CD Rom
you actually don;t really need the CD. you only need the cable to connect to a pc via USB. or you can connect using Bluetooth if your computer supports bluetooth
if your connecting via USB. be sure to set some settings first
go to <Phone Settings
>Connectivity
> USB Connection
> select MASS STORAGE
when you plug your phone. your phone should act like a regular mass storage device. Take note that only the External Memory is accessbile. (NOT the INTERNAL Phone Memory) so be sure to have a Memory card in your phone.
so it will be helpfull to set the default storage of pictures/files/etc to the external memory
May 13, 2008 | LG KU990 Viewty
Computers & Internet Logo
73 people viewed this question
Top Uniden Computers & Internet Experts
castletech
castletech
Avishek Samaddar
Avishek Samaddar
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
