Question about Murray Garden
How do I check a electric solenoid
How to test electric solenoid on carb.
    Master:
  • Murray Master
  • 645 Answers
You can run a 12V jumper to the solenoid, you should hear the solenoid "click" open and closed as you apply and remove the 12V.
Posted on Feb 05, 2016
Power star AE 3.4 No water flow. Why would the flow switch stay closed?
No power to the solenoid or the water inlet solenoid is stuck shut mechanically, or the solenoid is burnt out electrically. Test the winding of the solenoid to ensure electrical continuity. Test there is a voltage at the terminals of the solenoid when the water should be flowing in. If they both check out good you have a blocked solenoid valve.
Jul 02, 2016 | Water Water Heaters
My tractor dies when I put it in gear.
solenoid only engages the starter nothing else .it could just need the carb cleaned
Apr 16, 2016 | Garden
How can I replace carburetor?
I believe the electric solenoid is a fuel shut off. solenoid needs energized, normally with switch 12 Volts. other then float bowls are the carbs. identical, if they are switch bowls, should work. If not you will have to add switched power to solenoid, the link below looked similar to yours.
Generac Generator Carb removal and disassembly
McCulloch Generator Model FG5700AK
Jan 25, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
What is the piece sticking out of the bottom of the carburetor bowl on a cub cadet ltx1040 lawn tractor?
That is a fuel shut-off solenoid. It is an anti backfire device. You can test it. Remove it from the carb assembly, plug the plug into it ( if only one wire to plug then it needs to be grounded- hold it against part of the crankcase), turn the key on with the brake locked. You should see the pin on the solenoid suck in. Turn the key off and the pin comes back out. Repeat several times and make sure it doesn't stick. If the pin doesn't move then you need you either have an electrical problem or the solenoid has failed. Be sure fuel is flowing good to carb first, then be sure carb is clean, then suspect shut-off solenoid ( they are 70-100 bucks to replace)
Sep 02, 2014 | Cub Cadet Garden
Does a Briggs and Stratton 250035-0111-b1 have a fuel solenoid
The easiest way to check is to look at the bottom of the carb. If there is an electrical wire connected to the bottom of the carb, it has a fuel solenoid. Here is a youtube video Fuel Solenoid on engine
Nov 02, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
MY LAWN MOWER WONT START AND RUN UNLESS I POUR GAS IN THE CARB INTAKE . PUT NEW FUEL PUMP DIDNT MAKE A DIFFERENCE .WHAT IS THE ELECTRICAL PART ON THE BOTTOM OF THE CARB
The electrical part on the bottom of the carb is a fuel shut off solenoid. When you turn the key on, the plunger inside this mechanism retracts, allowing fuel to enter the carb. If you remove this it is easy to bench test with an alternate power source. Hope this helps.
Sep 11, 2013 | Husqvarna Lawn Tractor  25 HP 54in Deck...
John Deere LA 135 Fuel will not pass through carb. feul is getting to it .
yes solenoids do stick and at $130 for it try and clean it first and at that price i have cut the tip off and just added a manual fuel shut off valve in line to the carb
May 26, 2012 | John Deere Garden
Starting engine, Get Click, click, small amout of movement. Changed batt, sole, safe switch, starter, Remove Spark Plugs Engine Turns over Starter spins engine round & round. Plugs back in no good?
Check for spark at the spark plugs. If you have spark, the the problem is fuel related. If your carbs have an electrical solinoid below the bowl, unplug the wire connection and THEN unscrew the solenoid. There maybe a fiber gasket, be careful not to tear it. Unscrew the solenoid and check to see if clean fuel comes out of the bowl. If no fuel comes out, you have to clean the carb bowl and the jet. If clean and FRESH gas does come out of the bowl, then the (fuel shut off) solenoid is stuck in the OFF position. (the alcohol in our gas causes these solenoids to rust and stick) Buy a new solenoid.
NOW if you don't have spark, check the kill switches first, you may have 3 on a riding mower.You can temporaily bypass them if you don't have an ohm meter for testing.
Feb 10, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Changed battery,filled it with gas. Gas not getting to engine.
Remove fuel line at carb and see if gas flows freely.
If it flows freely and the carb is dry either the float is stuck closed or your electric fuel solenoid is unpowered/broken. The solenoid is under the carb. You can see a wire coming out of it. Unhook the wire and check it for power using a test light. If the light turns on with the key on you can remove the fuel bowl and solenoid and test the solenoid and inspect the float for free movement.
Also, make sure your fuel filter is clean and your inline fuel valve wasnt closed accidentally!
May 07, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Gerator runs about 2 min then quits let set then same thing. has a fuel solonoid on bottom of carb. think this may be the problem
Shutoff fuel supply and unplug wires from solenoid. Test for 12 VDC with ignition switch in "ON" position. (These solenoids are multi-polarity so ground one test lead to frame and check each terminal idvidually. Voltage on either one is acceptable.)
If voltage is OK ...
Unscrew the solenoid from the carb bowl for bench testing.
Be aware that raw fuel will spill from the bowl so USE CAUTION here!
Power up solenoid (again, polarity not an issue) and observe the plunger movement. It should retract slightly (but firmly) when power is applied.
If the solenoid is sluggish or it doesn't retract with a nice crispy "snapping sound", clean with carb-cleaning spray as needed. Work by hand and spray again. Then work by hand and spray, spray, spray....you get the idea. :-)
If still not working, replace the solenoid switch. They are a bit pricey so try to spray it once more!
Hope this helps,
Dolf-
Oct 15, 2009 | Coleman Powermate Powermate 5000W...
Garden Logo
29 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
