Question about Jeep Lantern
My clay paky astrospider will not light up anymore
I have a astrospider by clay paky lighting and it will spin and turn but it wont light up anymore
Build up of dirt in tub making clothes dirty... How do I clean inside of machine?
If you use powder detergent ( clay carrier) the build up is from undissolved powder ( clay)
It forms cakes between the spin tub and the outer bowl
The fix is to pull the washer apart and physically remove the caked up mud from all parts of the machine
The prevention of future mud is to use liquid detergents rather than powders
It works like this powder detergents have a small percentage of actual detergent in use and that is dried onto a clay base as a transporter agent
In the wash , the detergent is released but the clay will not dissolve
Most is pumped out with each spin but a certain amount remains , dries and starts the dirt process through the clothes
With liquid detergents there is the same amount of actual detergent but the carrier is water and that is diluted in the spin and completely flushed away
Dec 30, 2015 | Washing Machines
Vfr 800 fi
Hi pakie
the Fi light is fuel injection or ignition fault check fuse to ecu or engine stop relay and stop switch. Poss fault on angle sensor although unusual. If the light is flashing its a case of counting flashes to get fault code worse case is ECU fault
May 17, 2014 | 2000 Honda VFR 800
1997 Saturn SC2 wont start electrical issue
Some check light on dahsboard or "theft" system there?
Jun 26, 2012 | 1997 Saturn SC
The pottery wheel seems more like a joke than anything else its not molding the clay its just pushing it around weve tried more clay and it realy does nothing whats the deal
Sure it's a joke, it's a battery powered piece of plastic, but I guarantee you that if that machine will turn under a light load then you can do some fantastic work with it if you're willing to learn. Do a little looking on youtube, you can find lots of information concerning potter's wheels there.
lp
Dec 29, 2010 | Discovery Channel Discovery Ultimate...
Light comes on wont spin wsr-maytag mod m6d5600tqo ser mw2607338 type bwsr-nat-1206006-fm22 light wont turn off even with door closed dryer is not old new in 2008
Check the door switch. It just might be sticking which is why the light remains on and the dryer won't spin...
J. Lewis
Dec 21, 2009 | Maytag Dryers
Wont charge or turn on
There two possible hardware problems those are, battery and the system board. Try to isolate the problem by using other charger, if that charger is known good one, and there is a light on the device, then the battery is not holding charge and needs replacement, but if there is no light at all then it is the system board for replacement..better buy new one if you have no warranty anymore. if have problem on other charger. try to plug in to usb cable to your PC.
Apr 21, 2009 | GPS
Tv wont turn on, red flashing light
FLYBACK & HORIZONAL OUTPUT SHORTED
Apr 11, 2009 | RCA 32V524T TV
How do you make plates or bowls that are strong enough for everyday food use and you can use in the dishwasher? What material should you use (what kind of clay or other) and what is the process? Can I use...
You would want to use CERAMIC clay. The easiest way to make dishes is on a potter's wheel, but could be done with rolling pin and bowl / plate / cup to form. Roll clay anwhere from 1/4 to 1/2 inch thick, using flour or cornstarch to prevent sticking to work surface / tools / forms. Lay clay over form and trim off excess clay. As it will be very soft, you may want to leave it uncovered for a day or two so it can dry out and harden to near-leather hard.
You CAN use your oven to fire (bake), and for safe food / dishwasher use, after first firing, glaze with non-lead, non-toxic pottery glaze. *Careful not to get too thick as glaze WILL run during the second firing.
Your local Arts & Crafts / Pottery store should have all you need to make what you want, as well as DIY help on / with all aspects of pottery for even the greenest of beginners.
Mar 05, 2009 | Solar Southwest Pottery Light Switch Plate...
Clothes are still soaking wet after spin cycle and the wash cycle is complete.
Sounds like your bearings have gone in the back of the drum and damaged your water seal. the clay type substance is possibly water mixed with grease.
Mar 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Jeep Lantern Logo
44 people viewed this question
Top Jeep Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Jeep Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
