Question about TDK Office Equipment & Supplies
Battery use on tdk ads 6p
Does not seem to work with just batteries
How to replace ignition switch on a hyundai tiburon
Removal & Installation
Specific to:
Hyundai Entourage 2007-2008
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative (-) battery terminal.
  3. Remove the crash pad lower panel (A).
    Fig. Remove the crash pad lower panel (A)
  4. Remove the 2 screws (A) and the trip switch connector.
  5. Remove the crash fascia panel (B).
    Fig. Remove the crash fascia panel (B)
  6. Remove the screw with the ignition in the ON position (IG ON) and disconnect the 6P connector.
  7. Remove the ignition switch (A).
  8. Installation is the reverse of removal procedure.
    Fig. Remove the ignition switch (A)
Specific to:
Hyundai Accent 2006-2008
Hyundai Azera 2006-2008
Hyundai Elantra 2006-2008
Hyundai Sonata 2006-2008
Hyundai Tiburon 2006-2008
  2. Remove or disconnect the following:
    The negative battery terminalThe crash pad lower panelThe ignition switch after loosening the screw with IG ON and disconnecting the 6P connector
  3. Installation is the reverse of the removal procedure.hope this helps it is off autozone website
Aug 02, 2014 | 2006 Hyundai Tiburon
Unable to locate Olympus (B-01 4PE) Ni-MH rechargable batteries, for my Olympus D-395 digital camera. Unable to locate CR-V3X1 or LR6X2 at any retailer.
You don't need to use Olympus batteries. The D-395 uses two standard AA batteries, either disposables or alkalines. You should be able to find AA batteries at just about any department store, drugstore, electronics store, office-supply store, or supermarket.
Oct 16, 2011 | Olympus Camedia D-395 Digital Camera
Need a battery for TDK RM-3CDA REMOTE. Can you please tell me what it is? Thanks!
I could be wrong but usually, if its one of those small remotes a CR2032 battery should be it. normally sony uses those batteries for their products.
Feb 28, 2011 | TDK NA Accessories Battery For Sony...
Kamera tidak bisa digunakan, lensa tidak mau masuk/kembali/kamera tidak bisa dimatikan
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 08, 2011 | Kodak EasyShare C142 Digital Camera
TDK iVIBE users manual needed ADS-70BLK
Most of the functions are the same as the TDK iSLIM, and the user manual for this is available on the TDK website, http://www.tdk-media.com.sg/sg/products/peripherals/manual/iSLIM.pdf
Jan 11, 2011 | Audio Players & Recorders
I want to reset bios password of My Asus TUV4X, because I forgot the pasword instead.
remove all power from the motherboard. then remove the round back up battery from the circuit board. if the battery has a metal clicp on top it's best to gently slide a piece of paper between the arm and the battery as those clips are easy to break. some motherboards actually have a jumper you move to another position to accomplish this. i do not have the manual so this is the next best bet. wait about ten to fifteen minutes before removing the piece of paper and reapplying power. the password should be removed.
p.s. don't count on this working on a dell system
Sep 28, 2010 | ASUS TUV4X (TUV4X/533/PA/6P-UAY)...
My son dropped the flashlight acouple times and now it wont work
Either the bulb is burn or just faulty or the switch is bad.
Jul 16, 2010 | Surefire 6P BK 6P Original Personal...
Surefire 6p
Have you tryed looking for the button? Or you can try WD-40 but make sure that you wipe it down and when the button slipped out did you drop the flash light cause if you did you need to buy a new bulb.
Sep 08, 2008 | Camping, Backpacking & Hiking
HELLO, I HAVE A SONY Hi8 VIDEO CAMARA, THE Hi8 VIDEO TAPE CAME OUT OF THE CASSETTE(TDK Hi8 MP 120)ABOUT 10 INCHES, I BELIEVE BECAUSE THE BATTERY WAS VERY LOW. I CAN'T SEEM TO BE ABLE TO RETRACT IT BACK...
PLEASE DO NOT RETRACT IT BACK manually doing so ,will DAMAGE more the unit ,what you should do is plug the Video Camera AC plug and press the EJECT BUTTON , OR TRY turn in ON & OFF , TO SEE if it works.....
Apr 18, 2008 | Televison & Video
14 people viewed this question
Top TDK Office Equipment & Supplies Experts
jasbo
jasbo
Are you a TDK Office Equipment and Supply Expert? Answer questions, earn points and help others
