Question about Maytag PYE2300AY Electric Dryer
I have a maytag dryer that has power, but the light doesnt work(but it is not burned out) and the dryer will not start. timer works, can anyone tell me what could be the problem
    Habit-Forming:
  • 98 Answers
You probably have a bad door switch. When the door is open, the switch should turn on the light. When the door is closed, the switch should allow the dryer to start.
Posted on Jun 17, 2009
  • kh87
    kh87 Feb 21, 2013
    same problem as above except that my dryer runs but will not turn off when i open the door during the cycle. the light is out but that is not the problem as i replaced it with a new one. if it is a bad door switch, how do i fix it. thanks for the help.
Cabrio dryer has power and timer & and sensing working but doesnt start tumbling or drying
-Starter burn out. Replace new one
Att! Disconnect power before work on.
Good luck
Mai
Sep 18, 2014 | Whirlpool Dryers
Dryer doesnt work on settings
I have repaired (2) gas Maytag dryers that appeared to have timer issues. In both cases, it wasn't the timer, but the temperature sensors. In both cases, I replaced them and the dryers operated A-OK. The sensors signal the timer to advance. One sensor is located just beyond the flame where the gas is burning, the other just before the squirrel cage blower. In addition, there are (2) electrical coils located in front of the gas igniter assembly. If replacing the temperature sensors doesn't fix the issue, then replace the coils.
Apr 06, 2014 | Maytag Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Maytag dryer stopped working (model LDE9334ACE - electric). Dryer light DOES NOT work when door is open. Checked circuit breakers and that's fine.
Check your timer switch, that would cause you light not to work.
Also check the bulb, it may be burned out.
I hope this helps
Oct 01, 2009 | Maytag Dryers
Dryer will not start - lights all work - just switch will not start
This problem could be a broken drum belt, or the belt has come off the motor pulley.
One more...could be the motor is burned out, check to see if the motor is running.
If it is then maybe a bad timer switch
Sep 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
My maytag dryer doesnt work
hi thanks for the question i would check the power coming into the dryer a fuse couldbave blown
Sep 09, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start
your light should be working regardless of badtimer even, id check the incoming power supply, adn the connection behind the unit itself
Apr 12, 2008 | Maytag Performa PAV2200
Maytag atlantis doesnt run
change the copasitator this tells the machine to engage the motor
Oct 24, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag PYE2300AY Electric Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
