Question about Car Audio Receivers
Sony am/fm cd player x-plod 52w x 4 100 db
Am/fm will not work cd player works volume  is stuck nothing works but cd player no volume control no am/fm light in front of player works  no other buttons do nothing
SOURCE: No AM or FM yet cd player works
Maybe, there is a problem from the detector of you radio function to the amplifier. Try to check on it first or try resoldering from the detector section
Posted on Mar 10, 2008
  • 91 Answers
SOURCE: CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
Posted on Jul 06, 2008
  • 108 Answers
SOURCE: system lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
Posted on Mar 26, 2009
  • 13 Answers
SOURCE: sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Posted on May 06, 2009
  • 82 Answers
SOURCE: need wire diagram for sony x-plod to 04 colorado
hi my names josh firs things first you need a wiring harness for your vehicle if you dont have one you are faced with trying to do hardwire and i dont recommentd it on your vehicle. If you do how ever have a wiring harness you can proceed by doing all your wiring. The colors from the wiring harness should all match up your power wires you have two your ground you have one ground and the rest is your audio your sound. for your power you have a red wire and yellow wire your red wire is your acc or ignion switch witch allow the unit to come on when you turn the the ignition. your yellow is used for a constant 12volts to go to and it holds all your memory to the unit itself and then your ground no second guess its black and grounds the unit to complete the circuit the rest is pretty basic you have a set of wires coming out of the unit about four sets and these are your audio they are white and white/w gray then gray/w gray and white strip you have green/ and green/with a black or purple strip and the purple and purple/white or green strip
Posted on Nov 02, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
The setup is complete and the display returns
to normal play/reception mode.
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
– “DIM-ON”: to dim the
– “DIM-OFF” (z): to
deactivate the dimmer.
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
0 characters
1 Points
I have a sony mp3 xplod car radio, buttons wont work on it to operate probaly, any suggentions as to what is wrong?
I had the same problem with my sony CDX-GT540UI and solved it! I just kept clicking the "source/off" button when the display was showing the demo and suddenly it started switching to USB/CD/AUX etc. This means that the contacts inside the micro-switch were stuck in the down position, continuously making contact, and blocking the signals from the other buttons. Have to replace the micro-switch now.
Dec 29, 2011 | Sony XPlod CD Player w/MP3 Playback...
I turned the volume up the other day and it got stuck, it kept getting louder and louder. I turned it off, but now I can only use the CD player. I can't change the volume on the CD player. I also can't use...
You need to free the stuck switch. As long as it is jammed, it is going to send a signal to the microprocessor. The microprocessor can only handle one command at a time, so while the volume up switch is sending a signal to it, it will do nothing else.
Apr 07, 2011 | Sony CDX-R3300 CD Player
Sony CDX M730 won't operate manually, remote doesn't work either
my sony wnt flip down so i can change cds its stuck
Feb 16, 2009 | Sony CDX-M730 CD Player
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Sony CDX-GT310. Installed by Circuit City about 15 months ago. CD works fine. No sound from radio (both AM & FM). I've manually tuned through the range of stations with no reception. Checked...
Called a shop in VA and their opinion was that the tuner section of the unit failed. Cost of the part, $80. Then, labor and shipping. I can buy the new model (GT320) for about $95. I opted for buying a new unit.
Aug 11, 2008 | Sony CDX-GT310 CD Player
Sony CDX CA720X in my boat
Mac, I had the same problem, it was the hard wired remote at the Stern. When I unplugged it from the radio, everything came back to life and the radio and CD player are working fine. I'll have to replace the other remote at some point.
Hope this works for you...
Jul 16, 2008 | Sony CDX-CA720X CD Player
97 Jeep Grand Cherokee Limited Stereo problem
If you still have audio but unable to turn the volume, there are 02 possible problem:
- the volume control is defected will not respond ( electronic volume control; need logic low/high to activate the audio )
- the front control PCB is broken ( can be fixed if there is a small cracked )
If no audio at all then most likely audio output IC defected
Dec 19, 2007 | Cherokee (REF) AM/FM Stereo with CD Player...
External mp3 use
yes you do. go to an electronics store and buy an rca to ipod cable. just hook it up and enjoy. p.s. stay the hell away from fm transmiters. they are all garbage. hope this helps
Sep 03, 2007 | Sony CDX-CA710X CD Player
Car Audio Receivers Logo
155 people viewed this question
Top Car Audio Receivers Experts
xxxxxx xxx
Are you a Car Audio Receiver Expert? Answer questions, earn points and help others
