Question about Quest Queen Air Mattress
Pump isn't working on quest air mattress
Battery operated pump isn't turning on
Pump on my Intex air mattress shuts off before the bed is inflated
Pump is ng and needs replacement. Take it back if under warranty.
May 03, 2017 | Intex Pool & Spa
How to use pump to deflate air mattress
There is an intake port and an exhuast port on your Coleman quick pump. To determine and differentiate you need to turn it on and the one that is blowing air out is the exhaust that you would use to inflate the mattress. That leaves you with one other orifice that is taking air into the pump body. If you put your finger over that one it will suck down like a vacuum cleaner hose. That is the one that you want to attach the plastic adaptor nozzle to, and then hold the nozzle on the fill port of the air mattress. It will come down and into a vacuum state when it is all the way exhausted. Once completely deflated, they are much easier to fold back up and stow away. If you're at home and own a vacuum cleaner with a hose, save the batteries on your pump and use the vacuum cleaner. It will take about thirty seconds with that. Good luck with that.
Dec 29, 2015 | Coleman Quickpump
The air mattress was working fine the night before and then last night did not want to inflate. The motor does not start, it is plugged in, the socket works. I plug it in and go to turn the know to inflate...
most likely if you pump is not working, the intake must be clogged preventing air from passing and cooling the pump. That's how pumps and things like hair dryer short out. Or something could be blocking the fan from starting.even the power cord could be bad, I would check those things and go from their.
Jul 08, 2014 | Swiss Gear SwissGear Queen Raised Double...
How to inflate when camping with no electricity
Purchase a manual pump or a 12 volt pump that plugs into your cigarette lighter. Make sure your cigarette lighter works before you leave on your trip. There are also battery operated pumps.
Jun 05, 2014 | Coleman Camping 2000009831 AeroBed Premier...
I have lost the cap to my Quest queen air mattress. How can I get a reeplacement?
You can find a pair of Boston valve caps by Kwik-Tek on Amazon for $5. I don't know for sure for you, but I've never met a boston valve that these don't fit.
Jun 01, 2013 | Camping, Backpacking & Hiking
The comfort air air mattress pump on the model 833 has quit working it will not pump air I plug it in and it will engage the deflator but the air pump won't engage won't inflate the mattress. I check
If you feel like you can handle it you might try opening up the pump case to actually see the problem area. My guess is either the on/off switch is faulty or, if the motor is burned out, it just won't turn. THere may be brushes in the motor that could be replaced but all of this is speculation until you have a look-see.
Jan 05, 2013 | Heating & Cooling
How do I fill up my air mattress?
Most air mattresses come with either an electric or manual pump. You simply attach the pump to the valve on the bed and inflate your mattress.
Jul 31, 2012 | Camping, Backpacking & Hiking
What is an air mattress?
An air mattress is a mattress that is blown up using anelectric pump, manual pump or with your breath. They are then plugged and support the weight of the sleeper like aballoon.
Jul 09, 2012 | Camping, Backpacking & Hiking
I cannot find a manual for a blue magic super pump
See the instructions near the bottom of this web page: (picture at the top of pasted instuctions on th link)
http://www.abcwaterbed.com/pump2.htm
  1. IMPORTANT! - Unplug waterbed heater for safety
  2. Remove cap and seal and put aside in safe place.
  3. Remove any excess air from mattress - slide forearm or broom handle from the head of the bed toward the fill hole to move air pocket
  4. Attach the heavy duty hose to the hose valve coupling, connect to the waterbed mattress and other end to the pump intake side. Be sure to include O-rings. Gently push the coupling deep into the mattress.
  5. Attach garden hose to the discharge side of the pump, this hose goes to a tub, or a deep sink.
  6. Plug in the pump. When it starts it should have a low whirring sound, not a high whiny one. If water is not pumping immediately unplug the motor and check hose connections for tightness, verify there is no air in the mattress.
  7. As the pump removes the water, be sure the hose valve coupling at the mattress is pushed down in the mattress to maintain suction. Heavy phone books or other like items will help maintain proper position deep in the mattress.
  8. Keep pumping the water out and continuing to maintain the hose valve coupling position low in the mattress so it can keep pumping.
  9. Do not leave the pump or the area until finished. A dry pump can burn up.
  10. When the mattress is part way empty, you can place pillows under it at the head to help the water run downhill towards the hose valve coupling.
  11. Continue pumping until water flow stops or pump changes sound. The more water you get out, the easier your mattress will be to handle.
  12. If you are satisfied you have got as much water out as you can, remove the hose valve coupling and quickly replace the mattress seal and screw the cap on.
  13. If the mattress is to be stored for a period of time, pour in a large bottle of waterbed conditioner into the mattress before you cap and seal the mattress.
  14. We recommend rolling up the mattress from the head to the foot and carefully sliding one end into a wardrobe box. Another wardrobe box can be worked over the top of the mattress. Work one box into the other and seal both ends and tape the boxes together in the middle. You can now safely move the mattress.
  15. If you don't get enough water out, the fiber layers can easily slide out of position during moving and you may not be able to get them back into position when you fill the bed.
Nov 18, 2010 | Magic Pool & Spa
I have a Coleman Guest Rest Sleep System and I cannot get the air out of the mattress. I have taken the pump out of the casing and inserted it in the hole for deflating and I can't get it to work.
Is it battery or electricity operated? You might need to replace the battery or hook it up to the right outlet. Follow the instructions in inserting it to the hole. Make sure you press the deflate button and not the inflate button.
If the pump device is really not working, you can temporarily manually deflate the air bed by unhooking the air release nozzle. Press it slightly to allow the mattress to deflate faster. Step on the mattress lightly to force air out a bit.
Source: http://www.bestmattressreviews.com
Aug 11, 2010 | Coleman 10' X 10' Sundome Tent 9160K101
Quest Queen Air Mattress Logo
Top Quest Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
RatanbssBD
Level 1 Expert
Are you a Quest Rock and Ice Climbing Expert? Answer questions, earn points and help others
