Question about Lands Phones
Phone number message says number not available
How do I put a voice message on my phone when I am not available to take the call
Samsung Galaxy S6 Edge: How to put a voice message on phone when not available to take call:
Hello. If you did not set up your voicemail account yet..
Simply, on your S6 call your own phone number. When you do this it will ask you to set up your outgoing voice message.
Setting up Visual Voicemail
Visual Voicemail Samsung Galaxy 6 edge G925T
Feb 10, 2016 | Samsung Galaxy S6 Edge
Any text message i send goes to the out box and is either resending (to no avail) or listed as failed. I got the phone 3 days ago. It is a work phone with telstra. Nokia C%
The problem might be with "Message Center Number" which is different for different service providers.
You should call you service provider "Telstra" and ask them that number. You can then enter it in your mobile as mentioned below.
(Please rate the solution if helpful, Thank you)
Press "Menu"
Scroll to Messaging, press "Open"
Press "Options", scroll to Settings, press "Select"
Scroll to Text message, press "Open"
Scroll to Message centres, press "Open"
Scroll to SIM message centre, press "Open"
Scroll to Message centre name, press "Change"
Enter (your provider's name), press "OK"
Scroll to Message centre number, press "Change"
Enter (number provided), press "OK"
Press "Back" twice
Scroll to Message centre in use, press "Change"
Scroll to (provider's name you entered), press "OK".
Jun 17, 2011 | Nokia C5 Cell Phone
When a call comes in the phone doesn't announce the caller any longer. It just says number available. What do we need to do so it announces the name of the caller.
your phone gets calls in and will associate the name it reads. For example if your friend JOE calls tthen the system will say Call from Joe. But if the number is unlisted or blocked the Call from Number Available message will sound. If you don't have call display the all number coming in are imarked as Number Available.
Apr 30, 2011 | Panasonic KX-TG2356 Cordless Phone
My Nokia E63 display a message of ' Phone memory full " and also says 'Please delete files'. Which files to delete and how ? Thanks. Partha
I woud clean up your mobile phone by:
  • Copying your photos on your handset to your PC/Laptop and deleting most of the photos as they can take up a large amount of memory.
  • There are physical available memory limits to the total number of SMS/Messages in your Inbox/Outbox/Sent/Other folders: delete old SMS/messages.
  • There are physical available memory limits in the total number of contacts: delete all redundant directories entries.
You can also try using a bigger microSD card to alleviate your memory limitation.
Hope it helps.
Dec 14, 2010 | Nokia E63 Cell Phone
Can not send text messages.
Welcome to Fixya
If you can not send text messages, make sure that you have available credits. If you do, check the message center number under Message settings if the number is correct. You can obtain this number from your network provider.
Hope this helps.
Cheers!
Nov 22, 2010 | Cell Phones
E66 wont send a text, message goes straight to out box. can make and take calls, rcves texts but wont broadcast...swapped sim to another handset and works fine ??? any ideas ..Thanks martin
this problem is due to the text message service center number
text message service center number option is available text message settings
in this you can see service center number
Note down on any paper as it is (+9198xxxxxxxx)
then delete the service center number
after deleting create or add the new service center number
in this you fill the same number which you note down in your copy
save it and go back to main screen
then restart your phone
your can than send/ receive messages
if it not works go to the shop and get the text message service center number and follow the same procedure but the number you fill is you get from the shop. (NOT THAT NUMBER WHICH YOU NOTE DOWN IN YOUR COPY).
good luck
rate it
Jan 09, 2010 | Nokia E66 Smartphone
V tech 5.8 phone doesn't let ge digital answer machine answer? phone keeps ringing
MY NEW PHONEHAS A MESSAGE THAT MY NUMBER IS NOT AVAILABLE AT THIS TIME-I AM AVAILABLE-PROBLEM
Jul 01, 2008 | Uniden Cordless phone EXS9950
Sony Ericsson K510I
Back up the data first perform master reset all settings if this does not help reflash the handset.
May 18, 2008 | Sony Ericsson K510i Cellular Phone
MESSAGES
It largely depends on what model of switch the phones are connected to, however here are some links to user card and voicemail instructions, hope it helps.
http://www142.nortelnetworks.com/bvdoc/norstarbcm/t7316uce03.pdf
http://www142.nortelnetworks.com/bvdoc/norstarbcm/nvm4_reference_guide.pdf
To listen to your messages:
A number of options are available to you during and after listening to a message.
The table “Listening to your mailbox messages” shows the options and when they
are available.
1. Press ƒ·°⁄ to open your mailbox.
2. Enter your mailbox password and press OK or £.
3. Press PLAY to listen to your messages. For options,
refer to the table "Listening to your mailbox
messages".
4. Press ® to end the session.
Option Button Available
while
listening to a
message
Available
after
listening to
a message
Description
Backup ⁄
or
X Rewinds the message nine seconds and
resumes playing it from that point.
Copy fi
or
COPY
X X Sends a copy of the message to one or more
mailboxes. When you record the introduction
to the forwarded message, the introduction
must be more than three seconds long.
End of
Message
or
X Skips to the end of the message.
Envelope † X X Plays the information on the message envelope.
Envelope information includes the date and
time the message was sent and, if the message
was internal, the directory name of the sender.
This option is not shown on the display.
Erase °
or
ERASE
X X Deletes the message currently being played or,
if no messages are playing, deletes the
message just played. Deleted messages remain
in your mailbox until the session is ended.
(Refer to Notes 1. and 2.)
Forward ‹
or
X Advances the message nine seconds and
continues playing from that point. A message
can be forwarded as many times as required.
Feb 01, 2008 | NorStar T7316E Corded Phone
Lands Phones Logo
10 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
