Question about Smith Vantage Skullcandy Bluetooth Audio Helmet
Not turning on
There is a faint red led on when plugged in to charge
We lost the charger for a few weeks when we found it now the nabi won't charge.
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 | Nabi 2
Htc wildfire not fully charging always show the led red
When want to charge htc wildfire it is better you turn the phone of before charging. Plug in the charger and charge for about 20mins to 30mins then remove the charger pin-mouth for like 10secs and plug it back in. soon the red light will turn green in less than an hour..
Jul 16, 2012 | HTC Wildfire
I am trying to charge my phone right now but it is just a constant red light where it would usually be orange and it is saying 0% charged
did you run the battery completely flat?
my phone if it has gone dead, when plugged in to charge, has a red LED for about 5 minutes where you cannot even turn it on it is that dead. after those minutes pass the phone can then be turned on, and the LED changes color to orange to indicate it is charging and is also powered on.
Jul 12, 2010 | HTC G1
HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 18, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Same Problem
Hello, it was:
■ Charging LEDCharging LED
Or if the red LED remains on without turning green could mean a bad battery that no longer charges to 100% - get a new battery. Hope this helps
Jun 05, 2008 | Samsung Digimax i5 Digital Camera
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Smith Vantage Skullcandy Bluetooth Audio Helmet Logo
332 people viewed this question
Top Smith Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Smith Winter Sport Expert? Answer questions, earn points and help others
