Question about RCA DSB772WE Wi-Fi Streaming Media Receiver
Turning off after about 5 sec
Turns off after title screen
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Laptop turns on for 5 secs then turns itself off. The Toshiba screen appears and 2 secs later turns completely off. Is this a virus or some other issue?
sound like power supply or battery. first try running the laptop on battrey if the problem persists, then pull battry and try running on Power Supply only. if problem is fixed then your battery has gone bad.
Oct 12, 2009 | Toshiba Satellite A135-S2276 Notebook
It just turn on but the screen is green like 5 sec and turn back off
look for your sets "service" page not the regulae menu. Usually you have to hold the input buttin withthe power button for 2 secs. then you should get a very different menu, look for the factory settings and select that.
Apr 22, 2009 | Sony KP-57WS500 57" Rear Projection...
What is title screen?
The title screen is the first screen that pops up shortly after turning the system on.First it will tell you the system and then the company who made the game...then when it finally pops up and says Lion King...that is your title screen.
Mar 07, 2009 | Disney Interactive The Lion King for Sega...
Can somebody tell me how to program a RCA 312w universal remote control to a emerson tv I have the intruction but I can not understand them thak you.
This will work with any devise and the rca remote.
1. turn on the device you want manually
2.press and hold the devise key, while holding the devise key press and hold the on off key till it stays lit.
3. point it at the devise and press PLAY for 5 sec. until it goes off. If it doesnt turn off after 5 secs. press and hold play again for 5 secs. repeat till unit turns off.
4. After unit turns off press and hold Reverse for 2 secs. until unit turns back on.
5. After it turns on hit STOP. and your done. Hope this helps.
Feb 25, 2009 | RCA Universal Remote Control
This is for Ginko: Last Tuesday I described a problem with my Gateway 3520 going to "black screen" 5 secs after turn on. You analyzed a cooling fan problem. I removed the cover etc. and found that the fan...
see if the connectors are broken or working
the wires/board integrations are intact or not
see if it works
if not post any other data adn i will solve it
Dec 14, 2008 | Computers & Internet
Problem with TOSHIBA gigabeat model MEGX30
I have manual and driver for MEGX30. Let me know if you need it.
nenen9@yahoo.com
Nov 18, 2008 | Toshiba gigabeat X20 (20 GB) MP3 Player
The screen flashed and die really easily.
You need to go to Settings, [on the iPod] then go to Brightness. Mess with that and see what you like. I, personally, like my screen to be at 25%.
If that's not the problem, try going to Backlight in Settings. It gives you choices or Off, 2 secs, 5 secs, 10 secs, 20 secs, 30 secs and Always On.
Another issue that I've had is when I'm turning my iPod on from the Sleep option. The screen flashes and turns black when I do this. If you press the Menu button or any of the other options on the Scroll Wheel.
If that doesn't help you with your problems, then I probably haven't had them and suggest that you Google your issue.
Feb 16, 2008 | Apple iPod nano 3rd Generation
RCA DSB772WE Wi-Fi Streaming Media Receiver Logo
26 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
