Question about Microsoft X Box 360 Console 20 Gb Games,wireless Adapter,controller Bundle
Cannot connect uverse internet to Samsung un55fh6200
What is the backlight part number for samsung tv UN55FH6200. Is it BN44-00499A?
If you wish to get some details about LCD LED television ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 16, 2016 | Samsung Televison & Video
What kind of wifi remote/wireless do I need for a Samsung galaxy tablet?
If you have a combination modem/wireless router you should be able to connect your tablet to the internet. If not, you will need to either buy a wireless router that connects to your modem to broadcast the wireless signal or contact your service provider and get the combination modem/wireless router.
Dec 27, 2014 | Samsung Galaxy Tab 3 Lite SM-T110 8 GB...
I need the AT&T UVerse remote code for my samsung blue-ray player BD-D5700
Access the help section of the menu on your uverse connected TV. Select the option "Remote Control Setup". Select your style of remote and select the type of device that you want to program your remote to and then just simply follow the instructions provided on-screen.
Feb 01, 2014 | AT&T UVerse
No signal in all 4 hdmi ports on th new samsung 6050. Tried running from Sony receiver and then direct format uverse cable box. Still no signal. It is as if there is a compatibility problem. Help!
I would try connecting a dvd player to one of the HDMI input on the tv to be sure the tv is the problem.Try new HDMI cable 1.3 version. ATT uverse boxes are alway a source of problems and I would assume it was bad before I would condem the tv. If the tv is bad and it is under warranty an authorized servicer will replsce the main board.
Jun 08, 2011 | Samsung Televison & Video
I have Att Uverse and a Samsung LCD. We have
If your using the IR remote, the actual colors of the tv are what is causing your problem. What I have found to solve this is go to your local ATT corp. store and order the RF remote this will solve your problem. The techs don't carry these on their truck.
Jan 01, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Uverse standard remote control stops working at night
The remote stops working the Uverse box or the TV or both?
Try putting the Uverse box behind the plane of the TV screen so the I.R. that the TV emits doesn't get to the front of the Uverse box.
Mar 20, 2009 | Samsung HL-S5687W 56" HDTV
Samsung DLP 56' TV turns itself off when I initially turn it own. (I turn it on, then it shuts off for approximately 5-10 seconds and turns back on. Sometimes it does it a couple of times before it stays...
The problem is with the ATT UVERSE HDTV BOX and not the Samsung DLP TV. There is an inherent problem with the ATT UVERSE HDTV Box when using a HDMI cable. This was verified by the ATT UVERSE Technician.
Thanks,
Dec 13, 2008 | Televison & Video
AT&T Uverse HDTV
on some of the HD ready projection TVs they have a separate input for component HD, also some have a separate component input for HD
Mar 28, 2008 | Samsung HLN5065W 50" Rear Projection...
Microsoft X Box 360 Console 20 Gb Games,wireless Adapter,controller Bundle Logo
32 people viewed this question
Top Microsoft Radio Communications Experts
Are you a Microsoft Radio Communication Expert? Answer questions, earn points and help others
