Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Dispenser light is flashing and clicking sound
Clicking repeatedly and light flashing
2 Suggested Answers
SOURCE: clicking sound and lights flashing under water
Just fixed this same problem today. It turned out that a tiny drip of water from the icemaker had formed into a glacier behind the cabinet back panel. It was frozen solid from just below the icemaker down to the cooling coils. Removed the panels, melted the ice, fixed the drip and we were back in business.
Good luck,
Brendan
Posted on Feb 14, 2011
Water dispenser stops water flow
Sounds like you are losing power to the water valve. The only way to be certain, would be to use a volt ohm meter and test. Push in and out, repeatedly with a glass you can usually tell, if the dispenser switch Clicks or not. If the Switch were "no Good" you won't here it or Feel it "Clicking". It's not likely, but if it were mine... I 'd want to get back there and look to make sure I don't have a "Crack" in the plastic Fill Tube and it's getting wet back there -Just to be safe.
Nov 29, 2013 | Amana 22.6 cu. ft. Side-By-Side...
Tip
How to Reset Your Water Filter Light
<b>Amana:<br /></b> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>auto light</b> buttons on the dispenser for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>Press and hold the <b>dispenser lock</b> and <b>water</b> buttons for 4 seconds until the filter status indicator begins to flash, then release the buttons.</li></ol>or<br /> <ol> <li>After replacing the water filter, press and hold the Reset Filter pad for 3 seconds. The Order and Replace indicator lights will blink and then go off when the system is reset.</li></ol><span style="font-weight: bold;">Brita:</span><br /> <ol> <li>Press firmly and hold start button for 5 to 10 seconds.</li> <li>Four bars will appear in the display, one after the other, and flash. Do not release the start button until the 4 bars appear and start to flash. If you have difficulty pressing the start button, a capped ballpoint pen may be used to press the button down.</li> <li>A small flashing dot in the lower right corner shows the indicator is working.</li> <li>Every 2 weeks a bar automatically disappears. When only 1 bar remains make sure you have a new filter on hand.</li> <li>After 2 months, when all bars have disappeared, an arrow will flash at the top of the display reminding you to change your filter. </li></ol><b>Frigidaire<br /></b> <ol> <li>Press and hold the <b>reset </b>button on the dispenser until the green light flashes (up to 15 seconds).</li></ol><b>GE:<br /></b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol>or<br /> <ol> <li> Press the reset button on the dispenser for 4 to 8 seconds then release. </li></ol><b>Hotpoint:<br /> </b> <ol> <li><b>P</b>ress and hold the <b>reset water filter</b> button on the dispenser for 3 seconds.</li></ol> <b>Jenn-Air:<br /> </b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol><b>Kenmore:<br /></b> <ol> <li>Press and hold the button next to the filter light for 10 seconds.</li></ol><b>KitchenAide</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol><b>LG:<br /> </b> <ol> <li>Press and hold the <b>reset</b> button for 3 seconds.</li></ol><b>Magic Chef</b> <br /> <ol> <li> Press and hold the light and lock pads until the change filter light flashes. (approximately 3 seconds)</li></ol> <b>Maytag:<br /></b> <ol> <li>Press and hold the <b>lock</b> and <b>light</b> buttons (<b>lock and water</b> on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.</li></ol>or<br /> <ol> <li>Press the refrigerator's light switch five times within ten seconds.</li></ol><b>Samsung:<br /> </b> <ol> <li>Press the <b>ice type</b> and <b>child lock</b> buttons simultaneously for 3 seconds. NOTE: Hold the buttons for only 3 seconds. If you press these 2 buttons simultaneously for 5 seconds, the reset function ceases.</li> <li>Release the buttons and repeat the same step one more time. The water filter indicator light should turn green.</li></ol>or<br /> <ol> <li><span>Press and hold the "Alarm/Hold" button for 3 seconds.</span></li></ol>or<br /> <ol> <li><span>Press and hold the <i>Fridge </i>and <i>Power Cool</i> buttons for 3 seconds.</span></li></ol><b>Whirlpool</b>:<br /> <ol> <li>Press the <b>light</b> switch 5 times within 10 seconds. If the fridge has a <b>filter button</b>, press and hold it for 5-10 seconds.</li></ol>
on Jun 17, 2011 | Refrigerators
Soap dispenser motor turns but gets stuck and bends the arm up away from the dispenser. The washer makes clicking noises and stops. Took the top off to see the problem but then it did not repeat. I am...
this sounds like the same problem I am having. I think you need to just replace that arm which is called the dispenser lever. that plastic piece is too flimsy. hopefully the new parts are made better. I have to leave my top open and move it manually when it gets stuck.
Aug 08, 2013 | Kenmore Elite HE5t Washer
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The Control Panel/Dispenser light went crazy...
Sounds like a electronics problem would need to replace the board, LG parts are not normally expensive.
Apr 11, 2010 | LG LFX25960ST Stainless Steel French Door...
When i turn on the laptop the lights under the the screen flash
Hi from what you are describing it looks like the laptop heat sink (fan) needs replacing or the motherboard itself needs replacing
I would recommend that the laptop be booked into a reputable repair firm to investigate further
Feb 10, 2010 | IBM ThinkPad T40 2373 Notebook
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Ge Profile dispenser panel
Here is a link that will help give you a step by step process of elimination, click below and insure you have the correct model numbers as you move through the process, Thanks Sea Breeze
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Oct 26, 2007 | GE Profile PSI23NCR Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
372 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
