Question about Sony RM-Y905 Remote Control
Ir sensor on tv is not working
The remote works but how can i tell if the sensor in the tv is working
How to replace the IR sensor in a 42LG50 tv
how do you know the remote is working properly if it won't work the TV
Jun 01, 2015 | LG Televison & Video
Ir sensor is not working
check to see if your remote is actually working, If you have a digital camera with an lcd display point the remote at the camera and push a button on the remote, if the remote IR light is working you should see it light up thru the camera when you press the buttons.
Dec 20, 2013 | Vizio M420SL 42 in. HDTV
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Kdl-32l504
TV Parts Universal TV Stands DLP Chips ShopJimmy They should have the IR board for your Sony TV.
Sep 03, 2017 | Televison & Video
I have just bought a brand new remote for my Phillips 42 inch LCD tv from a reputable phillips website as the old one was not working (I recently bought it from my mate and his kid had eaten the on button...
Sounds like the IR sensor in the TV may be faulty, since you have now tried a couple remotes. Make sure nothing is on the IR sensor like tape, plastic, etc. IR sensor repairs are a fairly cheap and easy repair that can be done at your local tv repair shop. If you are still in warranty you can call Philips and tell them that you tried 2 remotes (1 brand new) on the TV and neither work. They should offer you a repair option. If you have any questions regarding your Philips warranty let me know.
Jul 18, 2011 | Philips 42PFL5332D 42 in. LCD Television
I have a 60 inch lg tv. The remote just stopped working Put in new batteries. Tv button lights up on remote but will not turn tv on.
Let me know model number of your 60 inch LG tv to find out possible cause of no remote operation.
I do not think that IR receiver is bad in your tv. Regarding dusty IR receiver lens, you can confirm it by sending remote signal by very close distance to tv.
There are few other possibilities of no remote operation problem instead of bad IR receiver.
Aug 25, 2010 | LG 42LC2D 42 in. LCD HDTV
Replacement Sony RM ED009 remote not working
Remote sensor on the tv may not be working. Try using a camera by aiming the remote IR sensor of the remote control at the camera lens then press and hole any button and check if you see a flicker of light. If you do, the remote control is transmitting, if not, the remote control is not working. This will tell you if the remote sensor on the tv is not getting the signal from the remote control
Aug 30, 2009 | Sony Televison & Video
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Magnavox Model #PR1910 C123
It is very very rare for this to happen. I would try other remote or you can google universal remote codes and look for other codes.
May 06, 2009 | Philips Televison & Video
Televison & Video Logo
16 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
