Question about GoVideo VR3840 DVD Recorder/VCR
Wont play on Bose 2800 lifestyle system
When I recordĀ a DVD and try to play it on my Bose AV28 lifestyle system it plays for a couple minutes or less and then stops. I hit the ff button and it will continue..(missing just a bit of show) otherwise I wait for awhile and it will start again... frustrating..... I have checked and rechecked settings to correct this issue but to no avail... any help?
SOURCE: Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Posted on Dec 24, 2007
SOURCE: wont turn on or off (completely frozen)
try upluging it
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: govideo dv2150 dvd stops playing
I had the same problem...... Freezing Frames...................I unplugged it from the wall and let it sit for a couple days, and it cleared all of the memory modules
Posted on Nov 18, 2008
  • 416 Answers
SOURCE: Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Posted on Dec 09, 2008
  • 16 Answers
SOURCE: dvd drawer opens and closes continually
the inter relay swich on the door is molfushing,or the open and close butten is bad'', try closeing the door and at the same time that the door close's unplug the power and then plug it back in after a few seconds and see what happens it my stay closed and then you can play it,, and it my stop doing that ''if not you will have to take it in to a repare shop'''' my names is ''james ''' let me know if this works for you''' you can e-mail ' me back at '' .
Posted on Jan 30, 2009
My bose lifestyle 48 say resolutio not supported when i try to play a dvd but i have sound without a picture. how can this be fixed
Is it a copied DVD or DVD-R / RW? If if says resolution not supported then it means that the DVD has a video format that cannot be played on the Bose even though the sound track is fine. The DVD may work fine on a PC as these can usually play more file types, but it could be a number of things causing it not to work and unfortunatetly there is nothing you can do.
Jun 29, 2014 | Bose Lifestyle 48 System
Dvd stuck bose ls28
Only a Bose repair technician can get the stuck CD out of the DVD ROM.
Jan 26, 2013 | Bose Lifestyle 28 Av28 Media Center With...
I have a Bose Lifestyle 35 Series II and want to know whether it's compatible with a DVD+RW. I'll burn it in a Toshiba recorder, finalize it and then play it on the Bose. Will it play?
Hi This what Bose say about formats
"The Lifestyle® 35 system plays DVD-video in interlaced format, as well as music on CD, CD-R (recordable) and CD-RW (re-writable). The system also plays MP3 files on CD and AM/FM radio. "
So by the sound of this i suspec that you may struggle with DVD/RW. but my best advice is try it.
Nov 10, 2009 | Bose Lifestyle 35 Series II System
Bose lifestyles v28 plays dvds in black and white
Check your video output settings in the menu. If you are using a composite video output and do not have the system sut up for it, you will get a B&W picture. Check your menu settings.
Aug 19, 2009 | Bose Lifestyle 28 System
DVD Format Problem in Bose LS 48
Follow this button sequence press when the error message appears"
Right Navigation - Up Navigation - Shuffle - Stop - Mute
this is make is play all discs.
Jul 27, 2009 | Bose Lifestyle 48 System
Bose av28 access menu using control buttons
when this happened to me,,,I found out it meant that the video decoding ASIC was out....I could not get any DVD's to play to the TV, and finally, the "settings" menu would not go on the television screen....this means you need to have the mainboard replaced, and after twice doing this,,,,the Tech on the phone told me that the Video Decoding ASIC is very susceptible to power spikes,,,so I put a big APC filter in front of it....
Jul 06, 2009 | Bose Lifestyle 28 System
Error trying to play a DVD on the Bose 3-2-1- Lifestyle system.
Unplug the power cord leave the DVD inside the Bose 321 system. Then plug the power cord back in. Voilla your DVD starts playing.
Jul 05, 2009 | Bose 3·2·1 II System
Dvd player wont play movies recorded by my friends. what is the problem?
Not all DVD players can play DVDR or DVDRW discs (writable DVDs) these players are however very inexpensive. Usually the ones that say they will play windows media file will work, but not always. See if you can find one that says it will play DVDR or DVDRW discs.
Apr 13, 2009 | Bose Lifestyle 28 System
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
GoVideo VR3840 DVD Recorder/VCR Logo
209 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
