Question about Panasonic KX-TGA470S Additional Handset
When I change the time on the phone to Daylight Savings Time, it will only hold for a few hours, for some reason when I look at the time again, it is back to the original beginning time before I chang
My phone won't hold the change I make to change the time to Daylight Savings Time. I make sure I press "save" when I make the change. I can place the phone back in it's cradle and the next time I look, the time will be back to the original time it was before I changed it.
3 Suggested Answers
  • 3 Answers
SOURCE: change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Posted on May 07, 2008
SOURCE: Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Posted on Mar 09, 2009
HELLO MY CLOCK DID NOT DO AUTO DAYLIGHT TIME HOW DO I FIX THE TIME TO ADJUST TO ONE HOUR A HEAD THANK YOU INGER WELCH
All you need to do to advance your clock an hour for daylight savings time, is hold down your clock button without letting it go. Then press your hour button once and you should be all set.
Most clocks that are older than when they changed the date of daylight savings time will either not change it for you on the right day anymore. Or they don't have that feature in it.
If yours does have an automatic daylight savings feature...you may find it helpful to take it off "automatic" and just change it manually from now on. That's what I do with my VCR. It has an automatic daylight savings time feature, but it's useless now that they have changed the date when we set our clocks for DST.
Some manufacturers will give you instructions on how to change the feature settings so your product will again work correctly for you. But not all will or can. You can look it up at your manufacturers website to know for sure.
Good Luck...and I hope this helps you.
Mar 13, 2011 | Vacuums
The clock changes for daylight savings time on the wrong day. it did this the past few times the time had changed. the date on the back of the unit is 2004. didn't they move the weekend of daylight savings...
Daylight Savings Time was extended in 2007.. (the Act was in 2004)..
So your clock worked fine for three years.. now.. if you can turn this automatic feature off I suggest you do and just set it manually... otherwise you will make the change.. and it will make it again for you!
Best of luck
Mar 12, 2011 | Vacuums
Samsung Impression :Daylight savings time moved all the appts
This is the second Samsung phone I have had that did this. The A707-Sync had the same problem. I called Samsung tech support and they told me to disable the auto-update feature for daylight savings. Not a great solution, but the only one I got.
Nov 02, 2009 | Cell Phones
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
How do i change clock to daylight savings time
Press and hold the plus button under the word time on your remote.
Nancy
Mar 08, 2009 | Bose Wave Radio
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
How do I change the clock?
fROM EXTENSION 300: Press #TD + Enter time in 24-hour clock using hours (2 digits), minutes (2 digits) and seconds (2 digits) + HOLD + Enter date using month (2 digits), day (2 digits) and year (4 digits) + HOLD + SPK to exit. This will change the time on all the phones and voice mail.
Mar 26, 2007 | NEC 80573 Corded Phone
Panasonic KX-TGA470S Additional Handset Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
