Question about Aerocool Window Evaporative Cooler Pd6802c - Pro Series Single Inlet
Can I get a manual for maintinance of my pro series evap. cooler .so I can do my own cleaning
Can I buy a manual that shows how to do annual cleaning,with pictures of my pro series evaporative cooler
ASUS P68Z Pro V shuts down
Check the CPU cooling fan. It is running, and if so, running correctly? Check the heat sink for the CPU cooler. They get clogged with dirt and cause overheating. Use canned air and blow out the heat sink to clear it of dirt and debris. DO NOT remove the CPU cooler to clean it. There is special thermal material on the heat sink to properly transfer heat. Removal will damage this and render the fan ineffective unless you have replacement materials available.
You can usually check the CPU temperature in the BIOS to ensure that the cleaning effort has worked.
Jan 06, 2012 | ASUS Computers & Internet
Trying to find owner's manual for CHC641E evap. cooler. Actually just need to swap a sticking float valve and the way it looks, I can't open up to get to the float valve without doing some minor...
Just go to a good hardware store and they will hook you up what you want is just a 1/4inch float they should have a evap. cooler section. And then you can get hot and sweaty. There is a pump and spider assy. that could be bad, but if you have no water in the bottom of the cooler your on track.
Jul 02, 2011 | Mastercool 67471 Evaporative Cooler Air...
My cooling Fan in my ATI RADEON X600 PCI Express Graphic Card his dead. Would like to know if their is somewhere I could buy one. Thank You
Here's a few,
http://www.directron.com/vichfa.html
Few more,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=4027&name=video-gpu-cooler&
One more time,
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=576&name=VGA-Cooling
Some information on installing a GPU cooler.
http://www.youtube.com/watch?v=zaGrRnd-d2I
(Also check out the other videos to the right)
[ GPU stands for Graphics Processing Unit. The ATI Radeon X600 series uses an ATI Radeon R300 GPU,
http://en.wikipedia.org/wiki/Radeon_R300 ]
If you are replacing using more than just a Fan, such as using a GPU cooler that also has a Heatsink attached, do not forget to Thoroughly clean the top of the GPU's case, and Properly apply fresh, new Thermal Paste.
If you have Any questions regarding installing an aftermarket fan, or GPU cooler, please post in a Comment.
We'll step by step through it by posting back, and forth.
Regards,
joecoolvette
Nov 16, 2010 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Does it need to be cleaned, if so. how is that done? AdobeAir /Mastercool model P700 serial number B150809633
Yes, it needs to be cleaned. Go to your local home store and (in the evap cooler section) pick up a bottle of evap cleaner/scale remover. Just follow the directions on the bottle. It will last MUCH longer with proper care and cleaning.
Jul 06, 2010 | Mastercool Portable Air Conditioner
Evaparative cooler system
Hi; If this is a rooftop unit it will usually have a removable plug. This has two purposes,wintertime shutdown,cleaning..alpharome416
Jan 17, 2010 | Mastercool 67680 Evaporative Cooler Air...
I need to know how to operate a dimplex eva20 evaporative cooler I have no operations manual and cant seem to find one?
hi :) ,
i'm guessing your in australia ( i'm in scotland ) , i cant find a manual online for your model of evap cooler , but heres the link for there tech support dept
http://www.dimplex.com.au/contact/
in the message box request a pdf of the manual for your model of cooler
hope this helps
Nov 09, 2009 | Kitchen Appliances - Others
Printer is printing very faint
you need to do head cleaning in your printer maintinence,
go to your control panel, find printer and faxes, open and right click on your printer. on the options select printer prefrences then maintinence tab, from there do head cleaning. you will have to keep running it till the test page prints clear and it does use a lot of your ink
hope it helps
Feb 13, 2009 | Brother DCP 115C All-In-One InkJet Printer
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Servicing a PS 1250 sewing machine
It's difficult to tell, but it looks like your machine is computerized. Most computerized machines require very little, if any, oiling. The only oiling recommendation I've seen for some machines is a drop on the hook. Follow the instructions in the manual and take your machine for annual service. Applying oil anywhere else could damage the computerized parts.
Feb 27, 2018 | Brother PS-1250 Pacesetter
Aerocool Window Evaporative Cooler Pd6802c - Pro Series Single Inlet Logo
Top Aerocool Clothing Accessories Experts
Da Doc
ray gallant
Tom Chichester
Are you an Aerocool Clothing Accessory Expert? Answer questions, earn points and help others
