Question about Brinkmann Outdoors Home Security Motion Detector Lighting System
Setting adjustments home security lights
Outdoor home sensor lights
I have an installed PIR exterior motion sensing light, but no instructions on how to set the controls. Now, if it senses motion, it will stay on for hours.
the sensor has at least 2 knobs maybe 3. one show hands of a clock one show sun. one may show sensitivity. the adjustment is low to hi the wider the adjustment the greater the setting check out this picture on ebay for the icon.
https://www.ebay.com/itm/Outdoor-12M-PIR12V-PIR85-265V-Security-PIR-Infrared-Motion-Sensor-Detector-GF-/292078238929?var=&hash=item4401383cd1:m:mRSg-Rlk4nJMZJH-BiKb2gQ
good luck
Oct 20, 2017 | The Home Security
My motion outdoor light is not turning off.
there can a few reasons for this happening
(1) something is moving within its range , this can be a bush or tree branch
(2) range /sensativity set too high use proper adjustments
(3) some models have a constant on mode that happens when you cycle power too light, turn pwr off and leave off for 15 min then turn back on
(4) lighting , the flashes of intense light drive these things crazy , if a strike comes close , sensor will become perm blinded and stay on
(5) light is defective
Feb 26, 2015 | OUTDOOR Home Security
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
I have outdoor security lights that run on a timer. Are there some that use a motion detector?
Yes, in fact most people have motion-detector activated lighting so they can know if there is suspicious activity outside of their home. Many security companies also offer systems that allow you to operate the lighting at your home from a smartphone or personal computer, which can help save electricity when it comes to outdoor lighting.
May 09, 2013 | Home Security
Light stays on all of the time will not turn off
Adjust the timer setting under the sensor it might be set to zero you shuld adnust to about 3 minutes or desidered time if set to minimum light will stay on if this does not help change unit its faulty
Sep 25, 2017 | Heath Zenith Secure Home Motion Activated...
Outdoors are turning out to be very white/cloudy
The camera is allowing too much light in. Try to adjust your ISO setting to a higher setting, that should work, unless your sensor is going bad
Mar 28, 2010 | Casio Cameras
Adjusting the sensitivity of my motion sensors
No adjustment on sensor other than masking its view.
AlarmProfessor.net
Jan 28, 2010 | GE Security Simon 3 Wireless Home Security...
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Brinkmann Outdoors Home Security Motion Detector Lighting System Logo
69 people viewed this question
Top Brinkmann Home Security Experts
Lawrence Oravetz
Are you a Brinkmann Home Security Expert? Answer questions, earn points and help others
