Question about Nikon D3200 24.2 MP CMOS Digital SLR with 18-55mm f/3.5-5.6 AF-S DX VR NIKKOR Zoom Lens
How to set the camera for 4 frames per second
Not fast enough
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
If it's not fast enough and your camera is set on continuous shooting it is most likely tou SD card that isn't fast enough? Try to get another one and be sure to get a Class 10 uhs-1 card. Also if your shooting in Raw it will slow you down a bit as well.
Posted on Jan 23, 2015
My camera should be able to take 7 frames per second but everytime I hold down the shutter, my camera focuses and takes a single frame. How can I fix this so that I am able to do the 7 frames per second?
It helps if you let use know what make and model of camera but normally if is a setting for a switch you need to move to burst mode.
Make sure your memory card rated at a high speed to handle the burst mode.
Jan 12, 2015 | Cameras
My D90 won't shoot the 4 frames per second. Is something turned off that I can't figure out?
The 4 frames per second shooting speed really only applies when you're shooting on manual focus. If you're not shooting a well lit scene or using an off-brand lens your camera will take a bit to auto-focus on your subject. Also if you're using the on-board flash, your camera will take a few seconds to recharge and fire again for the next picture.
Mar 06, 2011 | Nikon DSLR D90 Digital Camera
Nikon d2hs continuous high shooting only shoots at 1 frame per second not 8.?
In order for it to shoot at the theoretically possible 8 fps, the shutter speed has to be aat it highest setting and the aperture wide enough as well as the media card has to be a fairly fast one as well
(fastest write speed you can afford) and use j[eg mode not RAW (NEF)
Dec 28, 2010 | Nikon D2H Set Digital Camera
Continuous shot 3 frames per second is not
There are several possibilities.
If you're using the flash, the flash isn't going to charge that fast.
If your shutter speed is slower than a third of a second, you're obviously not going to get three frames per second.
If the camera is set on AF-C and the subject is moving, the camera may be having trouble tracking it.
If you're shooting RAW and have a slow memory card, the buffer will fill up quickly and slow you down. Try it with JPEG and see if it makes any difference.
If you have the exposure delay mode (custom setting #31) turn on, the camera will wait about 0.4 seconds before shooting, and this applies even in continuous mode.
Check all of the above. Set the camera to Manual exposure mode. Turn off the autofocus. Set the image quality to JPEG Basic. Set the camera to Continuous 3 fps. Now, press and hold down the shutter release button for five seconds. Does the camera take about fifteen pictures?
If you've checked all of these and it still won't do it, post an additional comment here and we can go from there.
May 25, 2010 | Nikon D80 Digital Camera with 18-55mm Lens
I seem unable to shoot any more than 4 frames per sec fz38 burst
You need a card with a fast write speed to achieve 10 frames per sec.
Jan 31, 2010 | Cameras
My eos40d on sports mode is not shooting at its proper speed at 6.5 frames per second. it shoots 2 frames per second and the piture cones out orange and not focus I only have this camera four weeks any...
6.5fps is only the manufacturer's indicative maximum. The camera will not always perform at this speed when conditions aren't suitable (too dark, for example). In Sports Mode, the camera decides the correct shutter speed for that scene. If it's not a very bright day, shutter speed has to be lowered (slow) to compensate for the lack of light. This results in a lower frame per second.
If you want to test the max fps, set your camera on Tv, and set the speed to 1/1000+ on a bright sunny day. Set the Drive Mode to AI Focus or AI Servo. If at 1/1000th of a sec, the Aperture value blinks in the viewfinder, you don't have enough light. Increase the ISO. You should be able to achieve 6.5fps. That's my experience anyway. Good luck.
Sep 18, 2009 | Canon EOS 40D Digital Camera
Video playing in fast forward with no sound
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
Jan 05, 2009 | Canon PowerShot G9 Digital Camera
3 frames per second
Hey there timdjones7, the camera will only shoot 3 fps when placed in Continous Shooting Mode. You can set this via the dial controls on top of your camera. Rotate it to the little icon that looks like a man running. Now you are set to go. Have fun!
Jan 30, 2008 | Nikon D40x Digital Camera
Not functioning d200
Nikon D200 High Speed Performance
© 2006 KenRockwell.com Film vs. Digital About these reviews
enlarge
I bought mine from Ritz here. I bought another D200 from Adorama here. Also try Amazon here. Adorama usually has D200/18-70 kits in stock here. It helps me keep adding to this site when you click these links to get yours.
HIGH SPEED PERFORMANCE
General:
My D200 is fast, smooth and quiet. Unlike my D1H, my D200 makes less noise and vibration. It doesn't feel as macho, and allows me to shoot in more places more discreetly. At five frames per second it just hums along sweetly, compared to my bigger cameras which always felt like something was going to come flying off of them from all the clattering.
Buffers versus Memory Card Memory
The D200 uses two very different kinds of memory for storing images.
We're all familiar with the CF cards used to store hundreds of images. These aren't that fast and card makers rate them for write speed. The D200 uses these for recording your images.
The D200, like all professional digital cameras, has a second very high speed internal cache memory called a buffer. You never touch this. This buffer memory stores 25 frames of JPGs, 21 frames of raw or 19 frames of raw + JPG.
The buffer memory is fast enough to store all these frames at the full 5FPS rate, or faster.
The D200 is never slowed by memory speed card. The D200, like other professional cameras, has a second independent set of processors which handle writing the contents of the fast buffer memory to the slower CF card. Because this writing is done with a second set of processors you never know it's working except for the green CF light on the back. The D200 can be busy for over a minute writing to the CF card and you still have the complete ability to shoot at 5 FPS and play back.
The buffer is so deep that even under the heaviest shooting it's unlikely that you'll ever fill it. Even if you fill the buffer you can still make photos and playback, just that the maximum shooting rate will lower a bit until the buffer write and frees up at least one frame.
It takes it a 100 seconds to write 400 MB of data from 19 uncompressed RAW + Large FINE JPG files to my 40x 1GB Lexar card. As a photographer you don't care how long it takes to write. So long as the buffer isn't full the camera works as fast as ever. Even if it is full you can shoot the next shot as soon as the buffer clears enough room. You don't have to wait for everything to write to make a next shot. Even with my slow 40x lexar 1GB card, a constipated buffer and huge compressed raw + JPG Large Fine files I can make a new shot every 3.2 seconds. With uncompressed raw + JPG Fine Large I can get off a new shot with a full buffer every 3.7 seconds. If you ever get to these limits you're doing something stupid. Just shoot JPG and you'll never be able to fill up the buffer faster than you can shoot. With Large FINE Optimal Quality JPGs the buffer clears at the rate of 1 FPS. With Large Basic Optimal Quality JPGs I can run at 2 FPS even with a full buffer. Use the smaller image sizes or the Size Priority JPG setting and you can shoot as fast with the buffer full as empty!
I've had to do seriously stupid tests to fill it up.
Shot Buffer Readout
A shot buffer is fast memory inside the camera which stores the shots you've just made. Your memory card is written from this buffer. Even with the slowest card on earth you can shoot as fast as you want, since it all sits in the buffer until written. Your card is recorded in the background while you shoot. The green CF light tells you this is happening.
The size of this buffer is how many shots it can hold while allowing you to shoot at 5 FPS. If it gets full the camera slows to only as fast as your card will accept data, which is about one frame per second . These buffers are why you don't need to worry about card speed.
I've never filled up more than 9 shots in a buffer. I don't shoot that fast. With a 25 frame buffer the D200 has far more than I'll ever use.
This is the number you see while the shutter button is pressed halfway. It usually looks like [r25], which means it's empty and can hold 25 more shots. Normally you'll see a big number like [527] or [ 1.3]k, which is how many shots are left on your card. As you shoot fast sequences you can see this number drop. When it drops to [r00] your buffer is full and the camera slows down its shooting until the buffer is recorded to the card. It's fun to look at when you get your camera, but since I never fill it up I don't worry about it. You'd have to be shooting many long high speed sequences continuously with a slow card ever to use much of this.
Jan 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
Any movement recorded in HD mode is not clear.
HD mode images may appear to move somewhat stiffly compared with SD mode or DV mode images. This is because they are shot at a rate of 30 frames per second compared with the 60 frames per second for the SD or DV mode images. The movie is shot at 24 frames per second, and looks good. So HD mode can have the same feel as a movie material. For smooth movement during video clips, we recommend you minimize rapid-panning or avoid shooting fast-moving subjects. Should you wish to record more natural motion in the picture, we recommend setting a slower shutter speed, or changing the recording mode to SD or DV.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Nikon D3200 24.2 MP CMOS Digital SLR with 18-55mm f/3.5-5.6 AF-S DX VR NIKKOR Zoom Lens Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
