Question about Roland Music
Td-3 My Roland Td-3 kit won't turn on when plugged in. I've tried everything including a new adaptor cord. Is there a reset or something else I can do?
  • 17 Answers
SOURCE: Hooking up Electronic drum kit to mider
sorry ...you haven't enough channels to mix all the kit ... you will have to run a stereo pair from the td8 to mg82 and mix it from the td8
Posted on Feb 02, 2009
  • 1138 Answers
SOURCE: For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Posted on Aug 06, 2009
  • 1138 Answers
SOURCE: the headphones output on my roland td- 10 is
The owners manual is here:http://lib.roland.co.jp/support/en/manuals/res/1811143/TD-10_eG.pdf Try initializing the TD-10. Check page 137. Check page 132 and 133. If the problem is still there, you likely have a jack problem. There might be a bad solder joint where the jack is mounted to the circuit board. If the warranty is up you can do it yourself if you are confident. Otherwise take the module in to have it serviced. Check here to contact Roland:http://www.roland.com/index.html
Posted on Sep 02, 2009
Testimonial: "I check all that all ready ,but I think there is a component damaged on the jack board .o even worse on main board."
  • 5603 Answers
SOURCE: i recently bought a TD-6 set, everything works
I have repaired one of these before.
On the version I repaired, there was a TINY trimpot accessable thru a hole that is semi-hidden. In the case I had, someone had actually destroyed the trimpot by forcing too big a screwdriver into the hole and smashing the trimpot.
It was relatively easy to open the unit and replace the broken trimpot...
WARNING, if that set has those "foam" cones under the snare type heads, expect trouble with them and the cones are NOT available anywhere for replacement. Essentially you have to MAKE your own now...
Posted on Mar 10, 2010
AlexMcG
  • 27 Answers
SOURCE: My Roland TD-6 Bass drum
There should be a nut and a cylindrical tightener at the bottom of the spring. If you loosen these, you should be able to pull the spring up and get the ring back onto the post. Then just tighten the nuts back down to where the tension feels right.
V-Drums don't all come with the same kick pedal--in fact they are often sold seperately--but this should be enough to help you with most basic kick pedal designs.
let me know if this doesn't make sense and tell me anything else you can about the pedal itself and I'll find a picture so I know what you have. This should work though. Good luck!
Posted on Mar 21, 2011
FCan get my Ipod to play through my Roland TD-20 Mudule
You need to get yourself a cable - with a 3.5mm male jack plug on one end (which will fit into your ipod), and a 1/4 inch male jack plug on the other end.
(you could use a lead with a 3.5mm male plug on each end, and used a 3.5mm female to 1/4 inch male adaptor to achieve this)
Connect the 3.5mm end into the ipod - play a track, with the volume at say, 75%.
Connect the 1/4 inch end of the cable to the 'Mix In' input in the back of your TD20.
Use the 'Mix In' control - at the top right hand side of your TD-20 module to control the volume.
If you wish only to have the iPod going to (for example) headphones - and not Front Of House (PA) speakers - which you will have connected via the Master and / or Direct Out(s); this can be achieved in the 'Mixer' settings (accessed via pressing the 'Mixer' button).
Oct 22, 2012 | Roland TD-20X V-Drum Sound Modul
Hey I recently purchased a Roland TD-4 and i have no idea how to hook up an amplifier to it. My friend gave me a little amp, and i've tried many ports and cannot get it to play outloud. I'd like it...
First plug a set of headphones into the Left audio out and see if you get any sound from there... NOTE: it will only be in the left headset and this is normal. Turn up volume control... note the level will be low as this is a line output, not headset. This is a test to see if there is audio.
Sep 02, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
Well the Roland td-4s is a superb kit. I've only had it for a few weeks now and the only issue im having is with the ride cymbal. It is a CY-8 cymbal that came with the set and it is dual triggered, but...
It sounds like the sensor is bad in the unit... If you have only had it a few weeks, exercise your warraaanty for replacement. Repairing the piezo sensor is NOT really a DIY project.
Dec 18, 2010 | Roland A: TD-4 Electronic Drum Set Pads,...
The headphones output on my roland td- 10 is sending sound just to a single channel ,I test it with diferent headphones ,same thing.
Aug 31, 2009 | Music
Aug 05, 2009 | Music
Feb 01, 2009 | Yamaha Mg82cx Stereo Mixer
Music Logo
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
