Question about Waring JEX450 850 Watts Juicer
Plastic piece that pushes sensor is broken
Plastic container that catches discarded stuff is broken where it is supposed to push in the sensor.
I have the beaumark juice extractor BM-473 it worked then i washed the removable parts now it wont work
the first solution is half right ... there are 2 hidden switches on the machine which are activated by shafts on the pulp container and on the top lid .if either is not on then machine will not work. possibly broke plunger on the pulp container ....or broken clip that holds the container in place
Jan 04, 2011 | Champion G5NG853S Household Juice...
Is any repair possible for the citrus attachment? the juicer cap will not spin when pressure applied down on the fruit.
I have the citrus attachment, but never use it because
it spits the stuff all over the place. Better off going
with a $15 or $20 dollar citrus juicer. Sounds like
the inside gearing may have broken and new one is
like $50.
Jan 04, 2011 | Acme 5001 Supreme Juicerator Juice...
Broken plastic screw from motor shaft
According to Jack Lallanes Support you need to buy a new motor! No replacement part for that specific part!
I have the same problem and also do not want to buy a new motor! Scam!
Dennis
Nov 21, 2009 | Jack Lalanne Power Juicer 250 Watts
On the shaft that produce from the Juice Extractor
ONE ACME AND OMEGA IT'S CALLED THE
CLUTCH NUT. GOOGLE THE MFG. OR
FOR YOUR BRAND'S PARTS.
Jun 29, 2009 | Hamilton Beach Juicers
The machine wont work
We had a Breville juicer which we just recently used but after a few hours it stopped working. May I know if whats the problem with it. We tried to open it but we can't figure what cause the machine to stop.
Jul 21, 2008 | Breville JE900 Juicer
Darn thing STILL won't turn on
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Jun 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Rotel Juicer
Once the handle has been pushed aside, it is easy to dismantle down to the perforated bowl. This is a push fir onto the black plastic boss and should wriggle off quite easily for cleaning.
Jun 03, 2008 | Juicers
How to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Dec 11, 2007 | Omega 1000 Juice Extractor
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Waring JEX450 850 Watts Juicer Logo
46 people viewed this question
Top Waring Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Waring Juicer Expert? Answer questions, earn points and help others
