Question about Furuno GP33 GPS Navigator
Driver for furuno gp33
Driver to connect furuno gp33 to openCPN running in windows 8
I need drivers for LD9900UP-GY for Del Computer running Windows 8
windows 8 usually runs everything or connects to internet & downloads it, try searching online for the driver manually & down load & run it.
Jan 30, 2013 | Logic Controls Pole Display 9.5mm 2x20...
Furuno FA-100 with MaxSea?
set io port speed for ext io 4800 on opencpn works ok
Feb 21, 2012 | GPS
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Connection to PC for Nav software
Assuming you have GPS input to your 1732 (i.e. GP310/320 sensor), you'll need a 7 pin NMEA data cable (000-154-028) wired to a D-sub 9 pin (serial) plug. The shield goes to pin 5, blue to #3, & white to #2. Jumper pins 7 & 8 together. The 7 pin cable goes to Data port 3 of the 1732.
Jul 12, 2010 | Furuno Navnet 1732 GPS Receiver
Need software to connect GP31 via serial to USB cable to W7 PC
Make sure you installed the driver for the serial to USB adaptor cable.
Jun 30, 2010 | Furuno GP31 GPS Receiver
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
How can I connect a LCD monitor in furuno radar fr 2827
You need a Furuno Monitor on that unit. There are special keypad functions involved with the monitor. I have a Furuno MU201CR/DC (20 inch) that i think is compatible, if you are interested.
Sep 18, 2009 | Furuno 1623 Radar 16nm Range
Connecting furuno gp32 nto laptop
This is a problem in Windows where NMEA data is interpreted by the computer as serial mouse inputs. There are various fixes. If you type Windows mininsterpret NMEA serial mouse into Google you will find lots of info.
Dec 11, 2008 | Furuno GP32 GPS Receiver
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Display position on PC
Hi miguel09,
You could try SeaClear It's free and runs not only on Windows systems but also on Linux with Wine. If you want to upload routes and waypoints then you can use this software from Furuno.
Best Regards
Lars Erting
Jul 03, 2008 | Furuno GP31 GPS Receiver
Furuno GP33 GPS Navigator Logo
29 people viewed this question
Top Furuno GPS Experts
Ron Dufek
Ron Dufek
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
