Question about Visual Land Tablets & eReaders
Device will not charge
I have attempted multiple times to recharge my tablet. It will not charge.
I've been charging for hours, but it's hardly charged.
If twice the time provides twice the charge, then 1. turn the device off while charging, or 2. consider the charger as incorrect or broken.
A battery on its last legs can exhibit the same thing. This is due to letting the battery get too low before recharging, even on a new battery, or it is an old battery (500 recharges often cited)
It is ever so important to fully charge a new unit 5 times and use most of the power in between IMO. After that, only the 'totally exhausted' condition is the worry..
May 14, 2016 | Tablets & eReaders
Why did it shut off and doesn't restart?
Is it recharging properly, might not be charged and is auto shutting down to save data.
Check your charger is working and the connection to the tab is good.
Bad fitting USB can cause failed charge.
Apr 04, 2016 | Samsung Galaxy Tab Tablet PC
Why is it continually indicating battery is overheating?
multiple issues can cause this. the first is an aftermarket protective case, the second is continuously overcharging it. the third is program(s) running in the background that will not shut down. The battery may be damaged as well. Step one is reconditioning the battery. run it until it is dead, recharge it until it is JUST charged full and disconnect the charger and run until dead again. This should eventually increase the time between the need for recharging if the battery isn't damaged. If it has an after market case remove it while doing this. If it is an android, download a handful of utilities from CM (free) starting with their Battery Doctor and their antivirus ( they are the best known and respected android developers) and run them. you can do this while you are conditioning the battery.
Battery Doctor will take over for the other apps that are telling you the tablet is overheating. and will automate the process of taking care of whatever is causing problems.
I use them on my Tablet and my Samsung Smart phone
Nov 13, 2015 | Nabi Jr. 5" Childrens Tablet
Does this unit typically have an issue with the battery holding a charge? It is approx. a year old.
It loses the charge because your device consumes a lot of power to keep the screen lit up. There is no problem with the battery other than the battery size is limited due to the size of your device.
Nov 01, 2015 | Tablets & eReaders
My tablet will not power on & shows no signs of charging
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Feb 22, 2015 | Tablets & eReaders
FORGOTTEN UNLOCK PATTERN
It is quite normal that after providing an unlock pattern to your tablet or mobile, you forget the pattern and attempt unlocking the device multiple times. In this process, many times your device gets permanently locked, and you no longer get any access to it. If you have forgotten your recovery email, you will not be able to unlock the device using that option as well. More.. How Do Unlock My Tablet if Forgot the Unlock Pattern or Recovery Email
Apr 17, 2014 | Tablets & eReaders
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
Dec 18, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
Charging battery on Tablet which is totally dead
Depends on how long it sat for with no charge. LION batteries dont recharge from totally being dead if they are left discharged for long periods of time.
Jul 29, 2013 | Polaroid 7-in. Internet Tablet - Other
Tablets & eReaders Logo
21 people viewed this question
Top Visual Land Tablets & eReaders Experts
Steve Mason
alex metro
alex metro
Lawrence Oravetz
Are you a Visual Land Tablet and eReader Expert? Answer questions, earn points and help others
