Question about Echo Garden
Can't pull the cord to start the engine
The cord seems to be stuck. never had this problem before
  • 10 Answers
SOURCE: can't get it to start. the pull cord is extremly hard to pull
take spark plug out you may have cylinder full of petrol or oil.crank motor over with rope see if its free.if liquid comes out blow out with air clean /replace plug & try again.check oil level also.
Posted on May 07, 2009
  • 58 Answers
SOURCE: Power Washer will not start - pull cord seems to
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
Posted on Aug 22, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
mikehowy
  • 177 Answers
SOURCE: Yard Machines 22'' mower, pull cord won't extend
is it flooding or is it second hand , some people cut the cord and dont fit it back properly , if it is flooding you will get hydraulic lock , answer to your question is carby service and over haul
Posted on Jun 07, 2010
tadgreen_2
SOURCE: MTD Yard Machines 22'' mower, pull cord won't extend
Found out that after unboxing the mower you have to pull the handle out 8 inches to a second set of holes for the T-bolts near the frame. Up under the frame of the mower the handles go down and block the blade from turning.
Posted on Jun 14, 2015
My B&S cord will not pull out. It is not stuck. Help
If the recoil starter was pulling free after you took it off, Are you sure the engine isn't seized?
May 11, 2017 | Garden
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
My recoil starter won't pull out it is stuck
Just take the cover bolts for the pull cord off. Then see if it works. There are usually two cogs that engage into the shaft of the engine. These cogs push outward when you pull the cord, engaging the shaft of the engine.
Oct 01, 2014 | Garden
When pulling start cord i cant pull and the shaft seems stuck
Could be a number of problems, including seized engine. Check to see if the engine break is releasing when you pull on the break release lever. Another check is the possibility that the rope has become tangled in the housing in which it resides.
Apr 12, 2013 | Poulan Pro PR550N22SH 22Inch Briggs ...
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
Mar 04, 2013 | BlackMax 3000 Watt Gas Generator - Powered...
Pull start won't pull, seems stuck.
When you pull the cord it will turn the blade. Therfore if the blade is stuck or clogged with clippings the starter cord will seem stuck. In addition, the throttle on the handgrip need to be fully depressed for the starter cord to work. Last, some mowers have a saftey which lock the starter if the wheels are engaged. Hope this helps. Bob
Apr 11, 2010 | Garden
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Pullstart wont pull
sometimes the float in the carb can stick causing the gas to fill the engine, this will prevent the engine from moving and therefore locking the pull cord. check the oil, is there gas in the oil? remove the spark plug and try to pull the cord again. gas may come out of the plug hole . if this is the problem you must change the oil and fix the carb. the other cause could be that the engine is seized. ouch.
I hope this helps
Sep 01, 2009 | Garden
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
27 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
