Question about JVC RX-552V Receiver
STAYS IN STANDBY MODE
IS THERE A RESET PROCEDURE
Toshiba 40BV700B that won't turn on. It is in standby mode, the standby light clicks (as if to about to turn on) then clicks again and stays in standby
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Feb 15, 2017 | Televison & Video
How do I turn off red light after installing new drum in Workcentre 555?
When u restart the printer automatically it will turn off.............
Jul 23, 2008 | Xerox Office Equipment & Supplies
How can I reset the tv? I don't have a remote. AMber and red light starts flashing after switching on and TV goes into standby mode
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 09, 2015 | Televison & Video
Code ck sr tuner no sound
Hello
So many improper commands send to the unit may make its system and memmory to be confused, and will not operate properly. Just reset the unit to factory settings, and try.
To reset the unit to factory default settings, so the following
[1] Press STANDBY/ON on the front panel to set this unit to standby mode.
[2] Press and hold TONE CONTROL and then press STANDBY/ON to turn on this unit. The advanced setup menu appears, in the front panel display.
[3] Press PROGRAM buttons to select PRESET.
[4] Press STRAIGHT repeatedly to select RESET.
[5] Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
This procedure completely resets all parameters of this unit including SET MENU parameters. However the advanced setup menu parameters will not be effected. The intial factory paramenters will be activated next time when you turn on this unit. To cancel initilization procedure at any time without making any changes, press STRAIGHT repetedely ot select CANCEL and then press STANDBY/ON.OK.
Apr 03, 2011 | Yamaha RX-V463 Receiver
My niece decided to push a rather odd sequence of buttons on the sound system and now nothing is setup correctly. while i have fixed the niece problem, i have yet to figure out why i cant fix the sound...
It's in the manual on page 59.
1 Press STANDBY/ON on the front panel to set this unit to the standby mode.
2 Press and hold
The advanced setup menu appears in the front panel display.
3 Press PROGRAM l / h to select “PRESET”.
4 Press
STRAIGHT repeatedly to select “RESET”.
Select “CANCEL” to cancel the initialization procedure without making any changes.
5 Press STANDBY/ON to confirm your selection and set this unit to the standby mode.
• This procedure completely resets all the parameters of this unit including the set menu parameters.
• The initial factory settings are activated next time you turn on this unit.
To cancel the initialization procedure at any time without making any changes, press STRAIGHT repeatedly to select “CANCEL” and then press STANDBY/ON.
Aug 14, 2010 | Yamaha HTR-6130 Receiver
We have a Xerox Workcentre Pro575; it has an error that says drum life warning; we replaced the drum with another drum that we know works, but the error stays on. What else can this error mean
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Nov 04, 2009 | Xerox Office Equipment & Supplies
Drum reset procedure toshiba dp80f
Press 'Menu' + '5' + '2' + '0' + '4'. RESET DRUM COUNT in display. Press '1' for yes. Press 'ENTER' to confirm. 'COMPLETED' in display. Press 'STOP' to return to the standby mode.
Aug 13, 2009 | Toshiba Office Equipment & Supplies
NEED DRUM RESET INSTRUCTIONS
    1. Yes
    2. No
Jun 24, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Workcentrepro 575 will not reset after replacing drum and toner. still says replace drum. will not print, send, copy.
This should reset that for you.
    1. Yes
    2. No
Aug 14, 2008 | Xerox Office Equipment & Supplies
WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
    1. Yes
    2. No
Mar 14, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
