Question about Cuisinart Furniture
Will not chill
Fans are working
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
Targus AWE81US grinding noise in fan
any luck y fans make a grinding noise. vegasguy913@gmail.com
Feb 25, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Targus awe81us disassembly
is it catching on a loose connection, have you damaged the bearings? try youtube .
Jan 26, 2014 | Targus AWE81US Chill Hub and Chill Mat...
Just replaced evaporator fan motor and plugged back in and coil getting cold and compressor working when should fan kick in
On some Kenmores it'shas a fancy term;it is called Pre-Chill. The compressor and compressor fan comes on but the inside fan does not till the evap chills down.
Sep 07, 2011 | Kenmore Side by Side Refrigerator
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Fan underneath frig is running but no cold air is coming into the frig or freezer
The fan that is under the frig is the condensor fan(the fan the cools the condenser coils and the compressor. It does not have a direct effect on the chilled air circulation inside of the frig. The evaporator fan is the unit that circulates the chilled air thru your freezer and frig. I am not sure what make model unit you have, but I have found that this fan motor is 90% of the circulation problems i have seen.
Jul 31, 2009 | Refrigerators
Refrigerator Compressor does not start
Is your freezer below your frig, like a drawer. If so does it still freeze the food. if this fact is true, then listen with the freezer drawer open to hear if the freezer fan is running. If it is running and your freezer is working then it could possibly be that fan that is the problem. This fan circulates the chilled air from the evaporator coil thru the freezer and the refrigerator. This problem is very hard to diagnose as the fan still spins but not fast enough to circulate the chilled air thru the freezer and frig. The minimum cost is around $300.00 if a service company does it. But if you can do it then you can possibly get the fan motor for around $80.00. This repair is very labor intensive as the access to the electrical connection is at the extreme rear of the freezer compartment.
Jul 23, 2009 | Refrigerators
Amana refrigerator will not chill
That model number does not come up for me.
Click on and enter model number
http://www.searspartsdirect.com/partsdirect/index.action
Jan 10, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Furniture Logo
Top Cuisinart Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
