Question about Whirlpool WTW4800XQ Washer
Does not spin out all of the water
See above
Won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
May 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
Door will not lock so washer will not spin. Water is draining out.
you need a wax motor and control board for the machine that is a common problem with the neptune. if you take the srews out of the head and look at the board yu will see a bad resistor just above a long blue resistor. make sure you upgrade your wax motor when you do the board or it will happen again
Feb 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Whirpool LSQ9200LQ Top Load water leaking on start of pump out
Transmission may be bad. When machinbe goes into very start of spin it should drain the water first and then machine will actually spin; tub should not be spinning. If it is, water cyclones up sides and will come out at tub cover. Only fix is to repl trans or select lower water level if I am correct in the diagnosis.
Nov 30, 2008 | Whirlpool LSQ9600L Top Load Washer
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
GE 1996 top loader agitation but good spin cycle
check the motor, the timer,the water level indicator in side the machine on the basket it will have a tube with a little box attached to it. It may be clogged or malfunctioning.
Apr 27, 2008 | GE WDSR2080D Top Load Washer
Whirlpool heavy duty washer won't spin out the water and is leaking
yes you need to replace transmission and i think the bearinds and seal are all together on that machine
if not replace seal and bowl bearing
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool WTW4800XQ Washer Logo
35 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
