Question about Garden
HUSKY 2600 PRESSURE WASHER
kuntrybaldgu
  • 7 Answers
SOURCE: I hAVE A 2600 PSI HUSKY PRESSURE WASHER, AND I
remove the pressure hose and turn your water supply on and water should flow thru the pump on out where the pressure hose is. If not you have a blockage in the pump.
Posted on Jun 07, 2009
tbirdfan1
  • 3051 Answers
SOURCE: absolutely no water pressure on my husky 2600 psi,
Hello there:
if you have already cleaned the filter for the hose than the regulating valve also has a filter assy with it too may want to check it also the nozzel will clog easily when sitting for a while. so you may want to check that out. ok
best regards michael
Posted on Aug 29, 2009
  • 553 Answers
SOURCE: Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to: http://huskypowerwasher.com/manuals_specs.php
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Posted on Mar 28, 2010
Testimonial: "thanks for the info. the # that I was referred to for manuals is - 866-340-3912."
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
SOURCE: pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Posted on Sep 03, 2010
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Husky 2600 psi pressure washer manual
It's called the recoil and you can have just the rope replaced to fix the problem
Oct 19, 2013 | Garden
Cannot find fuel shutoff valve
Some units does not have a fuel shutoff valve.
Sep 27, 2013 | Homelite 308653009 Blackmax Husky Pressure...
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
Jul 10, 2010 | Garden
I hAVE A 2600 PSI HUSKY PRESSURE WASHER, AND I HAVE NO PRESSURE GOING TO THE NOZZEL. i HAVE CHECKED EVERYTHING AND EVERYTHING IS ATTACHED.
Jun 07, 2009 | Garden
Absolutely no water pressure on Husky 2600 psi w/ HOnda motor
hook up water hose dose not pump water?
May 26, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
