Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell tower desktop Dimension 5100. Tower makes whistling sound.
When I push the button on the tower to turn on the computer, there is a high pitch whisting sound. I have already tried shutting it off and turning it back on -- also have checked all the connections to the tower and outlet. Need to know what the problem is and if a low tech person can fix it. Please help, I am very grateful.
  • Dell Master
  • 32,281 Answers
The high pitch sound could be a faulty monitor or the switch mode power supply. When the computer is running, turn off the monitor and if the sound is still there then the fault is most likely the switch mode power supply. Purchase a new switch mode power supply, make sure the wattage rating is the same or greater. Swapping the switch mode power supply is easy, take a note of the power connectors you remove so you can reconnect them with the new switch mode power supply. The power supply is usually fixed to the case with 4 screws. If the noise is from the monitor, then you should replace the monitor or repaired by a technician, a low tech person should not tackle this.
Posted on Jun 15, 2009
  • 32 Answers
Sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
When i turn On my PC this thing shows in the monitor. <300 XT BIOS P/N 113-A33437-102
Open the case, loosen the 2 screws holding the black plastic casingon the cooling tower over the CPU. Carefully remove, or tilt back to reveal cooling tower radiator and coil.
If there is a layer of dust built up (like there was on mine); carefully vacuum clean the radiator, cooling tower unit, fan and all other surrounding areas. Clean any residue from tower-to-CPU contact area.
Vacuum entire PC inside and out. Remove, reseat, vacuum video card. Reseat storage drive cables reseat the memory sticks, close it up and plug it back in start computer.
Jun 05, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
No power to tower. Pressing power on button on front of tower fails. Is there some kind of reset or fuse to look for?
There is no easy fuse. Did the computer get turned off at the back? Some power supplies have a switch on the top of the tower. Did the power strip get turned off? Have you verified that the outlet has power?
If this is not the problem, it sounds like a blown power supply. Do you have any lights on the system? If not, take the tower to a local computer shop and they can very quickly diagnose a failed power supply.
Sep 07, 2010 | Dell Dimension 4550 PC Desktop
My Desktop will not power on! When I press the power button it turns yellow but wont come on. If I press and hold power button, the yellow light goes out and a green light in the rear of the tower...
Please click this link Dimension 5100 and it will take you to the Advance troubleshooting guide for your Desktop. Browse for the Diagnostics light as this will let you know what is wrong with your computer. Most likely this kind of issue pertains to a Memory or RAM issue which can sometimes be resolve by re-seating it. For further details of your computer, follow this link.
Aug 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My Dell dimension 2400 monitor doesn't work when connected to my tower. It appears that it's off when I connect it to the Dell Dimension 2400 tower, but when I connect the same monitor to another computer,...
Hi! For dell machines when u unplug the video cable/VGA from the tower while the system is on it will show monitor self test.If you are seeing a black box moving around the screen it means that monitor is ok.Check connection between monitor and tower.Make sure cables are securely plugged in.Check if the tower is ok. There is a possibility that your monitor is ok but the tower is not.check the power button (whats the color) if amber/orange, this means there is something wrong the the tower. If its blue or white it means its ok.Also check if you are going to hear one beep, it means system is booting up properly. If tower is ok and you are using a expansion video card then try to use internal one, normally its the vga port above the usbs.If you are going to use onboard video card make sure you enable it first in bios.If all things fail, contact your manufacturer, if the system is under warranty then they will send a tech to check the machine.hope this helps...
May 28, 2010 | Dell Dimension 2400 PC Desktop
Hello, the green motherboard light on the computer
If there is no loss of functionality then I would say no.
Sep 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 - Will not turn on
open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
Jun 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 8400
IT MEANS that the processor is not getting cooled enough, try turning on the comptuer with the side panel open, dont reseat the cooling tower, however also check for the four lights on the back of the tower and post the same,,
Jan 25, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 5100
buy new power suplly for it ok
Feb 11, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
332 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
