Home | Weber | Genesis Silver C Grill | Weber Silver Genesis C r...
Weber Genesis Silver C Grill
Problem for Weber Genesis Silver C Grill
Weber Silver Genesis C regulator purging gas after reset process
By tomgrigg2002 on Jun 15, 2009
I reset the safety valve to eliminate common low heat problem on Weber Genesis Silver C. Now the grill reaches higher temp, but the regulator is purging gas through the vent? Does this require a new regulator, new procedure?
Best Solution
posted on Jun 17, 2009
Very Helpful)
meola64
Rank: Guru
Rating: 88%, 140 votes
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Weber Genesis Silver C Grill
Questions and Unsolved Problems for Weber Genesis Silver C Grill
Do you recommend Weber Genesis Silver C Grill?
Answer
Answer
Weber gas grill not heating up past 350. Tank is filled. I can smell gas but tank not leaking
Answer
How do you reset the safety valve on a gas grill.
Answer
The tank wasn't empty, although I refilled it. How do I clean the ignitor or do I replace it?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Weber Genesis Silver C Grill:
Top Grill and Smoker Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Grill and Smoker Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
