Question about Dacor MCS130 Millennia Electric Single Oven
The oven door will not close .
It appears the latch is in the way. The door was opened and allowed to "fall" forcefully.
  • 23 Answers
I just had a similar problem .the door would fall and i had to lift the top of my door hinge to close it .I found that the pin on the door hinge spring had fall.en out . I installed it back and now it works the way it should.the spring should feel tight with no movement.
Posted on Mar 26, 2014
OVEN DOOR LATCH BLOCKS THE OVEN DOOR FROM CLOSING ALL THE WAY. I CANNOT GET THE DOOR LATCH TO RETRACT.
Hi
There could be couple things. First, try pushing the door closed as you turn the handle. The latch may have dropped into the strike hole completely, binding the latch. Or you may try lifting the door as you try and open it. Friction is the one thing that most often happens causing a latch not to retract.
Another possibility is that the latch may have become detached from the knob set. If this is the case, you will have to remove the lock from the door, and from there you can open the door with a flat blade screwdriver. I recommend replacing the latch as well. If you remove the lock from the inside of the door, using a flat blade screwdriver you can pull the little 'T' that sticks out from the latch on the inside of the hole. This pulls the latch back away from the strike, allowing you to open the door.
There are different configurations of latches, and they activate like way. You could run into a long latch the lock runs through. You can use a large flat blade to activate that. If you have the type with the half moon, use the outside of the lock body, stick it into the half moon, and turn the whole thing to retract the latch.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | KitchenAid KEHC309JSS Electric Double Oven
Upper oven turn on and off then puts f9
F9 indicates a problem with the door latch circuit. Holding the door in the open position, push in the door switch until the cavity light goes off. Put the upper oven in the clean cycle and watch to see if the door latch cycles.
If the door latch mechanism is working correctly, the latch should stop in the closed position (the door will not shut all the way now). If the door latch does not even move and the F9 error appears, which is highly likely, you definitely have a problem with the latch circuit. (If the door latch did cycle to the closed position, cancel the self-clean mode to cycle the latch back to the open position.)
First, check that there are no loose wires on the door latch switches. Also check that none of the wires are pinched between the latch mechanism and the Oven Control Unit. Repair any wires that may be damaged and reconnect any connections that maybe loose. If you have just made any repairs, try putting the oven into bake mode with the door closed and test.
If there was no wiring that needed repaired and all connections looked good, test each of the door switches to be operating properly. Disconnect the wires from one switch at a time and perform a continuity test on the switch. In the open position your meter should read "OL", in the closed position it should emit a tone, or read "0.0". If either switch fails this test, replace the switch and test your oven again.
If none of the above conditions exist, the Oven Control is not reading input from the door latch sensor and needs to be replaced.
Apr 15, 2011 | Ovens
F5 error door locked
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
Dec 27, 2010 | Whirlpool RBD275PD Electric Double Oven
Error code F5EO
F5
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 19, 2010 | KitchenAid KEBC107 Electric Single Oven
Unlock oven door
The oven model 9815 shows you have a mecahnical latch. this latch has a switch that tells the control board what position it is in (open or closed). This switch should be tested.
Jan 07, 2010 | Magic Chef 9815 Electric Single Oven
I have a Whirlpool stove (model# RF385PXE)and I tried to start the self clean oven cycle the letters "door" appeared along with "E1" and "F5". The door is closed all the way. I even tried pushing it closed...
HI. This code is an indicating that the Self clean latch will not lock. Lock mechanism failure. follow the procedure below to address further.
1. If door latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Replace door switch.
D. Re-apply power.
E. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Nov 16, 2009 | Ovens
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Frigidaire wall oven FSC88W-5 The door is open
i have a feb386wech frigidaire wall oven that the left door latch came out and will not latch an stay in place
Aug 11, 2009 | Frigidaire Ovens
Whirlpool accubake oven door will not open e1 f5 and e0 f5 error codes
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Feb 09, 2009 | Whirlpool RBS305PDS Electric Single Oven
Kenmore oven door stuck closed
if you open the lid on your stove,you will probably be able to reset the switch manually (the latch).with the lid up its located toward the front behind the safety latch.(by no means attempt to force,bypass,or disable this switch)this is a safety feature designed to protect you from the high temps generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Oct 08, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Dacor MCS130 Millennia Electric Single Oven Logo
150 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
