Question about Covercraft Block-It 200 Custom-Fit Car Cover for a Ford F250
What is the pressure in the vacuum lines to defroster
Defroster wont switch to floor
    Sergeant:
    Champion:
  • 242 Answers
THERE IS NO PRESSURE IT IS VACUME. IT SOUNDS LIKE YOU HAVE A LEAK IN THE HOSE UNDER THE HOOD.
Posted on Aug 28, 2014
Need pitcure of vaccum lines on 1999 Ford Ranger v6 3.o air and heat blows only threw the defroster.
Item Part Number Description 1 18A318 Vacuum Control Motor-, Panel/Defrost Door 2 18A478 Panel/Defrost Door (Full Vacuum Position) 3 - Defrost Air Flow 4 - Side Window Demister Air Flow 5 18B545 Temperature Blend Door (Full Heat Position) 6 19860 A/C Evaporator Core 7 19A813 Air Inlet Duct Door (Full Vacuum Position) 8 - Outside Air Inlet 9 18A318 Vacuum Control Motor-, Air Inlet Duct Door 10 - Recirculated Air Inlet 11 18527 Blower Motor 12 19A566 A/C Vacuum Reservoir Tank and Bracket 13 - Vacuum from the Engine Intake Manifold 14 19B888 A/C-Heater Function Selector Switch 15 - Vacuum to the 4x4 Hub Solenoids 16 18495 Water Diverter Valve (Full Vacuum Position) 17 18476 Heater Core 18 18A559 Floor/Panel Door (Full Vacuum Position) 19 - Floor Air Flow 20 18A318 Vacuum Control Motor-, Floor/Panel Door 21 - Panel Vent Air Flow
Dec 09, 2016 | Ford Ranger Cars & Trucks
Why wont my 2001 ford windstar blow out of vents ? only on defrost?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • You probably have a vacuum leak , Pull heater control panel an check for vacuum . A broke vacuum hose or The vacuum selector valve is bad ! Or check for a vacuum hose in the engine compartment being off somewhere !
Mar 08, 2015 | 2001 Ford Windstar
1998 chevy blazer heater problems. wont switch from defrost to floor. stuck on vents right now. how do I fix this problem.
Most likely either the vent switching mechanism is dirty and won't switch the flaps -or- most likely the vacuum that is used to turn the vent flaps is either leaking and not pulling enough vacuum. You will have to get underneath the dash near the center, to check and see if you can manually move the vent flaps. If so, then most likely it is a vacuum leak in a vacuum line to the flap mechanism.
Dec 02, 2014 | Cars & Trucks
I have a 1995 dodge ram 1500 4x4 with a 5.2 l automatic. There is vacuum line sticking up behind the the engine with a vacuum brake hooked to it. where does that go
Not certain... just a thought... I believe Dodge uses vacuum solenoids to switch air flow from floor to vents and to defrost. Perhaps your loose line is from that solenoid. My '93 would go from defrost to floor when climbing a hill because of loss of vacuum. I hope this helps steer you to a solution.
Mar 23, 2014 | 1996 Dodge Ram 1500 Club Cab
Climate Control - Heat and cool work fine. Air flow is directed to defrost /floor. No indication (Sound or sight) that the vacuum diaphrams are being activated. The display on the dash matches the...
Does your vehicle have manual or automatic climate control ? You system is stuck in floor an defrost mode ?
03 mercury grand marquis hvac air flow .-13qahwfdndst2y1hypmr2cdq-4-0.gif Item Part Number Description 1 18A318 Vacuum control motor-floor/defrost door 2 - Defrost air flow 3 18A478 Floor/defrost door 4 18476 Heater core 5 19860 Evaporator core 6 19805 Blower motor 7 - Outside air inlet 8 19A813 Air inlet door 9 18A318 Vacuum control motor-air inlet door 10 - Recirculated air inlet 11 18B545 Temperature blend door 12 18A559 Panel door 13 - Panel air flow 14 18A318 Vacuum control motor-panel door 15 - Floor air flow 16 - Vacuum from the engine intake manifold 17 19A563 A/C vacuum check valve 18 19A566 Vacuum reservoir tank and bracket 19 19980 EATC control
Pull the control panel an check for vacuum
vacuum lines hvac 03 grand marquis-13qahwfdndst2y1hypmr2cdq-4-2.gif Item Part Number Description 1 White Air inlet door 2 Yellow Floor/defrost door 3 Red Floor door 4 Blue Panel door 5 Black Source vacuum 6 - Not used
VACUUM APPLICATIONS CHART-ELECTRONIC AUTOMATIC TEMPERATURE CONTROL Switch Port Vacuum Harness Hose Color Func- tion Manual Override Selector Buttons OFF MAX A/C NORM A/C VENT FLOOR FLOOR/ DEF DEF 1 White Air inlet 2 Yellow Floor/ panel (partial) 3 Red Full floor 4 Blue Panel 5 Black
Source
May 21, 2017 | 2003 Mercury Grand Marquis
A\c blows cold but only blows out defrost and floor wont blow out vents whats the problem
Sounds like you are having trouble with the environmental station actuators, either you have a vacuum leak, line disconnected, or bad vacuum control switch, or a bad vacuum actuator. I had this problem in my truck, I found the actuator next to the accelerator down by the floor disconnected, I hooked it up and all is well. Hope this helps, let me know.
Aug 04, 2010 | 2002 Ford Mustang
97 Lumina...Switch stuck on defrost vent and
I had same problem . There is a vacuum resovoir tank located behind the left front splash shield . The vacuum line behind the battery goes to it . I removed two 5/32 screws just in front of the tire that hold the splash shield to the fender , carefully flex the shield away from the fender and take a look . I found the vacuum line had come loose , plugged it back on and everything works . Hope this helps
Dec 20, 2009 | 1997 Chevrolet Lumina
1996 ford mustang convertible ac blows cold only from defroster
Does it still blow out the floor and defrost when you set the switch to those positions or does it alway blow out the defrost no matter what? If you can get air to blow out to the floor, then it sounds like you lost the switch that controls the airflow to the vents. If it only blows out the defrost, then you probably lost the vacuum to all of the switches. When the vacuum is lost, it will only blow out the defrost. Check the smallest line on the vacuum distribution block located in the corner near the brake master cyclinder. That line provides the vacuum to control the direction of airflow within the cabin.
Jun 08, 2009 | 1996 Ford Mustang
Vent controls wont switch from defrost to any other selection replaced switch already I have a 2003 ford windstar, heat and cold air will only blow from the window defrost vents, any other selections...
You have a vacuum leak.Defrost is the default postion(no vacuum).
See if you can locate the small black vacuum line that goes inside the vehicle on the passenger side near the heater core. The trace it back,should see it going to a canister then to the intake manifold.Make sure it is not disconnected or broken somewhere.
Mar 02, 2009 | 2003 Ford Windstar
Covercraft Block-It 200 Custom-Fit Car Cover for a Ford F250 Logo
29 people viewed this question
Top Driving Comfort Vehicle Parts & Accessories Experts
Robert Plante
 John
John
 AEpittsburgh
AEpittsburgh
Are you a Driving Comfort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
