Question about Panasonic Heating & Cooling
Panasonic air con cu-80c51xe need manual
Old uit works but not well, tryign to find manual...
4 Suggested Answers
  • 582 Answers
SOURCE: i need a circuit board for a Panasonic CU E7GKE
IF ALL YOU NEED IS THE CIRCUIT BOARD TRY A1 PARTS THEY HAVE JUST ABOUT EVERYTHING AND AT VERY GOOD PRICES
Posted on Aug 10, 2009
  • 534 Answers
SOURCE: Panasonic CS/CU-A242KR Air conditioner leaking water
OK lets see what we can help you with here. The condensate drain is clogged. There are a couple of ways to clear this clog so lets give it a try. If you know where the drain for the a/c is located outside (usually by the outside condenser unit) it will be a pipe that is just sticking out of the side of the house, if you find it take a wet/dry vac and place it on this pipe and turn the vacuum on and make a seal with your hand this should unclog the drain. If you don't find this pipe outside the house then go to the furnace and you will see at the bottom of the furnace a pipe (PVC) white, this is the drain for the unit inside. Take the wet/dry vac and have it at the ready in the event the clog is further down the line than at the furnace itself now the fittings on this pipe should not be glued together due to the ability to access for this very purpose. Take the pipe apart at one of the fittings and place the wet/dry vac on the end of the pipe towards the furnace and using your hand make a seal and evacuate the line. Do this to both sides since you don't know where the blockage is. If you are unable to separate the pipe at any fitting you will need to cut the pipe and at the spot of the cut you will need to repair it with a sleeve. Remember that the drain pipe is plastic and is made of pvc so you can get a repair coupling from any home improvement store for this repair.
Hope this helped you some
Dave
Posted on Feb 21, 2010
  • 34 Answers
SOURCE: Hi, I have a Panasonic Reverve Cycle Air Con Split
Lift front cover on indoor unit, lift up then pull out the filters and wash them with dish washing liquid in water and hose them off.
Posted on Apr 24, 2010
Whats south africa zip code
POSTAL CODES FOR SOUTH AFRICA
Place Name Street Code Province FAERIE GLEN EXT 71 0081 Gauteng FAERIE GLEN UIT 2 0081 Gauteng FAERIE GLEN UIT 24 0081 Gauteng FAERIE GLEN UIT 3 0081 Gauteng 245 more rows, 2 more columns
postal codes for south africa - South African Postal Codes in South ...
www.blaauwberg.net/postalcodes_results.php?value=f zip codes in South Africa Google Search
Oct 29, 2016 | Miscellaneous
LN-S4695D replacement stand
do you by chance have a pic of your old broken neck? I have a few Samsung pedestals in stock.
Dec 01, 2012 | Samsung LN-S4695D 46 in. LCD HDTV
The compressor will run at times, but the condenser fan doesn't start and the unit shuts off on either high pressure or the compressor overheats. Why doesn't the fan start with the compressor? The unit is...
IF UIT IS A YEAR OR LESS OLD YOU ARE BETTER OFF CONTACTING THE MANUFACTURER, SINCE THE UNIT HAS WARRANTY FOR PARTS AND LABOR DURING THE FIRST YEAR THEY WILL COVER ALLSO THE FREIGHT COST.
CALL THEM 858-566-7473
Mar 16, 2011 | Breezaire WKE 6000 Wine Cooler
I'm tryign to figure out the empowering tecnology password and trying to figure out how to get the I,o,p,j,k,l,m cause they r showing up numbers instead of letters
Some how you have locked the FN key. Have a look at your manual to see how to unlock the FN key. Manufacturers use different methods.
Feb 03, 2011 | Computers & Internet
Verlichting van klokje van de volvo 850 is uit
i do not understand what you are saying but stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
Nov 18, 2009 | 1995 Volvo 850
Lens van mijn Ricoh Caplio R 6 gaat niet meer in of uit
Hoi Van de caplio R6 zijn geen onderdelen leverbaar, de camer moet worden aangeboden aan Ricoh Nederland ze zullen je een website aangeven waar je de gegevens kunt opzetten en daarna pas de camera kan opsturen aan hun servicecenter
Groet,
Rob Rotronica
Apr 15, 2009 | Ricoh Caplio R6 Digital Camera
I want the instalation for vga carrd compatabile at motherboard msi pm8m-v plz... thank you very much
I tried to look up you manual for *********** board but I would have needed the CPU socket and the type cpu either AMD or INTEL. so I am answering w/o the info. If your motherboard  already had an VGA video card Either AGP,PCI or PCIe. on a slot all you have to do is buy the same type of card, plug it in where the old one went, install the sofware that came with it, including the driver.
If you are tryign to install a present card. Go to the manufactors website of that card ,download the software and driver and instal the same. Write back with more details and we can  provide  more specific directions.
http://global.msi.com.tw/index.php?func=downloadindex
Jan 05, 2009 | MSI PM8M-V Motherboard
Install my UIT webcam driver
i dnt have the uit webcam driver cd so i can u tell me from where i cab donwload the driver <<
Jul 26, 2008 | Computers & Internet
ok I lost my driver cd for the u i t webcam driver and I couldnot found it please i need help to make work >> thanks
Jun 22, 2008 | Logitech QuickCam Chat Personal Web Camera
I cannot get to video
We had the same problem for many years. We purchased a GE multi remote and put in the program code. You then need to hit the input button on the remote to change to the various options and select the one that works. It worked for us so I hope it works for all.
Sep 03, 2007 | GE 27GT620 TV
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
