Question about Samsung UN55EH6050 55 LED-LCD 1080p HDTV
Need to replace broken screen
My tv was dropped while moving it and the screen is cracked. Screen shows multi incoherent colors on two thirds of the screen with picture and sound from right side of screen only.
    Top Expert:
  • Samsung Master
  • 75,311 Answers
Contact the authorized service centre for Samsung. This is a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 25, 2014
  • 84 Answers
SOURCE: CRACK LCD TV SCREEN
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it. LCD screens really break easily as you know. http://www.tv-armor.com
Mike
Posted on May 21, 2008
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Posted on Feb 08, 2009
  • 11 Answers
SOURCE: I dropped my 32" Samsung LCD LNS3241D and the screen cracked help
i will buy th broken tv, i have the same tv but with power and inverter problems. let me know.
thank you
Posted on Sep 15, 2009
jerryg50
  • 1689 Answers
SOURCE: when i turn my tv on 3/4 of the right side of the
The problem is most likely in the image processor area, or the backplane circuitry on the screen itself.
The service rep would be equipped to properly service your set. You should call LG to find out who in your area is able to service your set.
If the set is out of warranty it could be fairly expensive to service.
Jerry G.
Posted on Dec 16, 2009
SOURCE: Samsung LN52A550 lcd tv has
I have a similar problem. I have vertical colored lines in the middle and right side of the screen is black. Here is the photo. Do you guys think it is the T-con board?_853.jpg
Posted on Mar 02, 2011
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
Jun 15, 2011 | Computers & Internet
I dropped my lenovo x100e think pad and when i power up the screen is muti colored. the screen itself is not cracked.. can this be fixed?
Hi shodo37,
Most of the time when you're getting multi colored screen after the machine was dropped is caused by a cracked LCD. But I understand that it's hard to believe that screen is broken if you're not seeing any physical crack on the outside. By going to BIOS it will help you determine if your screen is cracked. If you don't know how to go to there follow the steps below:
>>> Turn on your PC, once it start up keep on tapping F2 button. You'll be routed on the page that has blue background. If on this page you'll still get multi colored screen then it's indeed broken screen. No crack on the outside but there's something needed to be checked inside.
Broken LCDs can only be fixed by replacing it with a new one. And if system is still under warranty you may contact Lenovo. They will offer you options to resolve the issue depending on what your warranty covers.
Hope this will help you.
Thank you for using Fixya.
Dec 11, 2010 | Lenovo ThinkPad X100e 287673U Notebook PC...
My daughter just dropped her acer aspire netbook. Only half of the screen is visible the other half is white and black with a line down the middle
Dropping the netbook will have probably broken the LCD screen.
There is no other way to repair the problem without replacing the screen itself. You can however use a external monitor and use the keyboard to toggle between the two screens.
I know this is probably not what you wanted to hear but unfortunately LCD screens are fragile so a good knock can crack them causing only one half or the part or the screen which is not broken to show. The backlight itself sounds like its working as there is still light showing behind the cracks.
Regards.
Mar 14, 2010 | Acer Aspire One PC Notebook
POSSIBLE CRAKED LCD SCREEN
the only possible repair is to change the lcd panel.. which would probably cost you more than the tv itself.. sorry for the bad news
Jun 04, 2009 | Televison & Video
Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Jun 02, 2009 | Toshiba REGZA 47HL167 TV
My douther drop the DS and now the screen is multi color, how can i change the DS??
Most probably the multi color screen means te screen is broken. Both screens (top and bottom ) can be replaced, it takes a special tri-wing screw driver to open the DS, price of the screen to replace +/- € 20.
Please rate
Jan 06, 2009 | Nintendo DS Lite Console
Broken plexiglass tv screen
crack in the screen? well the screen is the end result of small light mirrors and a color wheel that can project up to and more than 16 million colors ...... so that screen is very important to recieving these light shows and making a nice picture. a crack ... yes you will see all kinds of crazy things... and even probably on your wall behind you.
need new screen and problably a nice check on alignment.
Oct 24, 2008 | Samsung DLP HL-P5663W 56" TV
Acer aspire 5050 laptop color lines on screen
you can try pulling the screen apart and re-seating the ribbon cable, but the lcd might be broken, or one of the controller lcd chips might either be cracked or broken. Trying to reseat the lcd ribbon cable might help, but if there is a visible crack in the screen- you will need a new screen.
Nov 24, 2007 | Acer Aspire 5050-3242 Notebook
Samsung UN55EH6050 55 LED-LCD 1080p HDTV Logo
80 people viewed this question
Jerry Greenberg
Jerry Greenberg
