Question about Outdoor Technology DJ Slims Wireless Headphones
Need dj slims bluetooth driver windows 7
Device not properly installed
Running windows 7 home on one PC and windows 10 on another. I don't have the installation disc anymore, and the drivers I downloaded from Dell don't seem to work.
Daisy Mae,
The Pocket DJ is not compatible with Windows 7 or Windows 10. If you plugged it into your computer and it did not recognize the device or show up in "My Computer' then it will not work. You would need a windows 7 and Windows 10 drivers.None are available..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 01, 2016 | Dell Pocket DJ MP3 Player
CAN'T FIND WIN7 DRIVER FOR BLUETOOTH HBS-200 HEADSET
Unfortunately, Windows 7 removed native support for bluetooth headsets, for absolutely no reason.
The drivers are actually not needed for the Headset specifically, but rather for the A2DP and AVRCP profiles and audio sink. The downside is that Microsoft's Bluetooth stack does not support either of these.
So you need a Better Bluetooth Stack, so it understands all of the virtual Bluetooth devices.
These directions work for almost any headset that has issues when connected to Windows. Sadly, there is no really good well-defined set of drivers for Windows Bluetooth, so it will frequently take some finagling.
1: Find the correct and absolutely most-up-to-date drivers for your Bluetooth hardware on your computer. In -MOST- cases, the chipset is Broadcom, however manufacturers such as Dell and others tend to put some odd wrappers around the chip so their drivers are required. If not, the direct-from-Broadcom drivers will work.
2: IF the Bluetooth hardware is already detected by Windows, delete it from device manager. Reboot the computer if this was done.
3: On reboot, Windows may detect it and reinstall it fresh. This is fine if it does. Allow it to install and reboot if it requests.
Once the Windows stack is installed properly, you can install the updated stack. With Dell drivers and other OEM computer manufacturer drivers, Windows may not detect it to begin with, however having Windows drivers first is not necessary with these drivers.
4: Install the proper driver. With the Broadcom driver, this will only work if Windows has already installed. With OEM drivers, this is often not necessary. Reboot if necessary.
With the happy stack installed, and the headset paired, you will find that instead of just Handsfree Telephony and Headset services, you will also have Remote Control and Audio Sink services.
Headset/Handsfree: Mono 38kbps audio out and also a microphone input. This is what is used for phone calls. It sounds horrid, mind you.
Audio Sink: Stereo happiness and joy. No microphone input.
Once you have these devices, you do need to set your audio playback device appropriately for Stereo Happiness and Joy.
Mar 27, 2014 | Radio Communications
Windows 7 bluetooth driver drivers
As you do not mentioned the device on what you want to install.
so i can say you can check out following link:
http://drivers.downloadatoz.com/download/14174,bluetooth-peripheral-device-driver.html
Dec 18, 2013 | Samsung HM1100 Bluetooth Headset
Bluetooth peripheral for windows 7 not installed
check device manager if there are drivers that were not properly installed, usually with (!) symbols or reinstall drivers using vista drivers.
http://support.lenovo.com/en_US/detail.page?LegacyDocID=migr-63572
navigate down to the modem/bluetooth drivers, try to use VISTA drivers.
Mar 31, 2013 | Lenovo 3000 N100 Notebook
Bluetooth can send but cant recieve
Maybe there is no Windows 7 driver for it. That's one of the pitfalls of Windows 7.
May 08, 2012 | Computers & Internet
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
Problem with the Gemini Sound Products Gemini CTRL-SIX USB/MIDI DJ Controller and Audio Interface It wont be detected by the computer's usb on WIndows 7
In the control panel, sounds and devices, check that the device is in each list under audio, voice, and hardware tabs and that your device is the default device. If NOT in the list, the CORRECT drivers are NOT installed or not properly installed.
Jul 23, 2011 | Gemini Sound Products Gemini CTRL-SIX...
My lenovo brand laptap needs bluetooth peripheral device to be install
You can download the drivers from Lenovo support site. Just check the back of your notebook for the serial number. Lenovo support downloads ask for that. Then, get the drivers. Turn on the bluetooth first.
Download the XP drivers for Windows XP. For Windows Vista and Windows 7, download the Vista drivers. Be sure to install the Chipset drivers first and then the sound drivers. Only then can you install bluetooth drivers properly.
Oct 22, 2009 | Lenovo 3000 Y410 Laptop
Install macally icekey keyboard to windows?
It is only for Mac, there are drivers available from the site, all OS and OSX.
Driver - Macally Peripherals
www.macally.com/driver
Keyboard & Mouse · Bluetooth & Wireless · Webcam · Hub & Adapters ... usb. IceCam. IceCam Driver for OS X 10.4 to 10.5 ( updated on 2/16/2008); IceCam ... ICEKey installer for PowerPC and Intel-based Mac OS 10.4 to 10.6(32-bit system only) ... USB 3.0 to Gigabit Ethernet driver for Windows XP/Vista/7/8 (9/10/2013).
Amazon.com: Customer Reviews: Macally USB Slim Keyboard - ICEKEY
https://www.amazon.com/Macally-USB-Slim-Keyboard-ICEKEY/.../B00006HYP6 ... and review ratings for Macally USB Slim Keyboard - ICEKEY at Amazon.com. ... F9 for me shows application windows, F10 isolates the window and F11 ... Macally USB Slim Keyboard ICEKEY Google Search
Mar 13, 2017 | Macally iceKEY Keyboard
Outdoor Technology DJ Slims Wireless Headphones Logo
116 people viewed this question
Top Outdoor Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Outdoor Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
